STACK ASR920
IvoSilva
I need to know about a ASR920 technical information, I did not find it in the DataSheet.
Is it possible to do stacking with ASR920?
Okay!!
So can let me know how many sfp+ port required in router..?
And why you need to stack the router..?
Jasmeetsingh
We cannot stack the asr router..
why you need to stack the router..??
I've attached one link for datasheet of asr router.. please check.
https://www.cisco.com/c/en/us/products/routers/asr-920-series-aggregation-services-router/datasheet-listing.html
One solution is that.. instead of using router you can use layer 3 switch with stacking.. but that depends on requirement..
can u elaborate the requirements..?
I'm working on a project with ASR920 where I need more 10G SFP+ ports.
In this case I need a L3 Switch that does MPLS, OSPF and Q-in-Q, do you have any idea which switch would suit me?
Okay!!
