ssengotaiyan
Beginner
Stacked VLAN Supports on 7206 VXR NPE G2
  Can some one please confirm whether we can enable the stacked vlan features on 7206vxr NPE G2?
int gig0/1.xxx
encapsulation dot1q XXX second-dot1q XX
4 REPLIES 4
Philip Olsson
Beginner
I have this running on UBR7246VXR with NPE-G2.
No reason to expect that it should not work for you.
interface GigabitEthernet0/3.1200079
description Customer79
encapsulation dot1Q 120 second-dot1q 79
Hi Philip
   The below is the code i am running on 7206 vxr npe-g2.
c7200p-advipservicesk9-mz.122-33.SRE14.bin
PE1(config)#int gig0/2.14
PE1(config-subif)#encapsulation dot1Q 14 se
PE1(config-subif)#encapsulation dot1Q 14 ?
native Make this as native vlan
<cr>
PIX-PE1(config-subif)#encapsulation dot1Q 14
Any idea which code it will support?
System image file is "disk2:/ubr7200p-jk9su2-mz.122-33.SCG.bin"
/ Philip
Hi Phillip
  Thanks for your reply. I am sure the code which i am running should be supporting stacked vlan. But command is not available.
Does it related to bootstrap image?
I am running below.
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
It has to be T series to support Stacked vlan ??
