Shurenste
Beginner
Telemetry not working on sub-interfaces (XE)
Telemetry  (MDT) sensor-path for interfaces is not sending any info about sub interfaces (logical interfaces) on latest IOS-XE.
We found that counters for sub interfaces are not in IOS process but only in  SNMP one (that is probably the key difference with normal interface's counters pushed on MDT subscription).
We have tried different workaround without success.
Do you have an idea if there will be support for this in future or if there is an elegant workaround?
It is very hard to say that Telemetry are supported on XE if we cannot see any sub interfaces counters-))
0 REPLIES 0
