Highlighted
Beginner
Unequal Load Balance on Etherchannel (L2/SW3400ME)
Hi, i have a problem with my L2 port-channel between 2 SW ME-3400-24TS-D (12.2(44)SE5), there is a unequal load balance and i don't know how to fixed. Should I change the load balance method?.
All four ports have the same config, except one (int fa0/1 on SW_2) that have this commands:
MAMANIVLN1P1IRA1#SH RUN INT FA0/1 | INC hold
 hold-queue 4096 in
 hold-queue 4096 out
Should i change this hold-queue config?
Here more outputs where you can see the diference, one link has 2mb and the other link has 60mb,, that's a big diference, i would like to know how to solve this:
SW_1#sh int fa0/9 | inc (Desc|rate)
  Description: !!!!!! HACIA SW_2 !!!!!
  Queueing strategy: fifo
  5 minute input rate 2088000 bits/sec, 2065 packets/sec
  5 minute output rate 25000 bits/sec, 46 packets/sec
SW_1#sh int fa0/10 | inc (Desc|rate)
  Description: PORTCHANNEL10 HACIA SW_2
  5 minute input rate 1905000 bits/sec, 1948 packets/sec
  5 minute output rate 63348000 bits/sec, 6095 packets/sec
SW_2#sh int fa0/1 | inc (Desc|rate)
  Description: Hacia SW_1_Fa0/9
  30 second input rate 27000 bits/sec, 48 packets/sec
  30 second output rate 2385000 bits/sec, 1996 packets/sec
SW_2#sh int fa0/2 | inc (Desc|rate)
  Description: PORTCHANNEL10 HACIA SW_1
  5 minute input rate 63567000 bits/sec, 6114 packets/sec
  5 minute output rate 1935000 bits/sec, 1976 packets/sec
more outputs...
SW_1#sh etherchannel load-balance
EtherChannel Load-Balancing Configuration:
        src-mac
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source MAC address
  IPv4: Source MAC address
SW_2#sh etherchannel load-balance
        src-mac
SW_1#SH MAC ADDress-table INTerface po10 | inc Total
Total Mac Addresses for this criterion: 297
SW_2#SH MAC ADDress-table INTerface po10 | inc Total
Total Mac Addresses for this criterion: 66
In advance thanks for the help.
Content for Community-Ad
Cisco COVID-19 Survey
