Highlighted
Beginner
CMX backup automation
Dear community:
We would like to create a job to automatically create a backup every night in the CMX.
We have created this script:
Inline image 4
When we execute the script when cmxadmin user, we have this error:
Inline image 2
With root user, we have another error:
Inline image 1
Any suggestion on how to proceed?
Is anybody doing unattended backup in CMX?
Thanks!
Carolina
17 REPLIES 17
Highlighted
Frequent Contributor
Re: CMX backup automation
Hi Carolina,
The images of the script and errors are not visible.  Please edit or resend message with images or text.
Thank you,
Matt
Highlighted
Beginner
Hi Matt,
This is the script content:
cmxos backup --path /tmp --offline
When I try to execute it, I got this:
[cmxadmin@RKAVLMSETEST01 ~]$ ./backup.sh
Traceback (most recent call last):
  File "/usr/local/lib/python2.7/runpy.py", line 151, in _run_module_as_main
    mod_name, loader, code, fname = _get_module_details(mod_name)
  File "/usr/local/lib/python2.7/runpy.py", line 109, in _get_module_details
    return _get_module_details(pkg_main_name)
  File "/usr/local/lib/python2.7/runpy.py", line 101, in _get_module_details
    loader = get_loader(mod_name)
  File "/usr/local/lib/python2.7/pkgutil.py", line 464, in get_loader
    return find_loader(fullname)
  File "/usr/local/lib/python2.7/pkgutil.py", line 474, in find_loader
    for importer in iter_importers(fullname):
  File "/usr/local/lib/python2.7/pkgutil.py", line 430, in iter_importers
    __import__(pkg)
  File "/opt/cmx/sw/lib/pymodules/cmxos/__init__.py", line 5, in <module>
    from __main__ import cmxos
  File "/opt/cmx/sw/lib/pymodules/cmxos/__main__.py", line 23, in <module>
    from cmxctl.util import Backup
  File "/opt/cmx/sw/lib/pymodules/cmxctl/util/__init__.py", line 7, in <module>
    from cmxconfig import CmxConfig
  File "/opt/cmx/sw/lib/pymodules/cmxctl/util/cmxconfig.py", line 22, in <module>
    from cmxagent.util import ParseConf
  File "/opt/cmx/sw/lib/pymodules/cmxagent/util/__init__.py", line 10, in <module>
    from qlessqueue import QlessQueue
  File "/opt/cmx/sw/lib/pymodules/cmxagent/util/qlessqueue.py", line 10, in <module>
    import cmxjobs
  File "/opt/cmx/sw/lib/pymodules/cmxjobs/__init__.py", line 5, in <module>
    from redisCleanupTask import RedisCleanupTask
  File "/opt/cmx/sw/lib/pymodules/cmxjobs/redisCleanupTask.py", line 5, in <module>
    from abctask import ABCTask
  File "/opt/cmx/sw/lib/pymodules/cmxjobs/abctask.py", line 6, in <module>
    class ABCTask(object):
  File "/opt/cmx/sw/lib/pymodules/cmxjobs/abctask.py", line 9, in ABCTask
    handler = logging.handlers.RotatingFileHandler(LOG_FILE, 'a', 1000000, 5)
  File "/usr/local/lib/python2.7/logging/handlers.py", line 117, in __init__
    BaseRotatingHandler.__init__(self, filename, mode, encoding, delay)
  File "/usr/local/lib/python2.7/logging/handlers.py", line 64, in __init__
    logging.FileHandler.__init__(self, filename, mode, encoding, delay)
  File "/usr/local/lib/python2.7/logging/__init__.py", line 911, in __init__
    StreamHandler.__init__(self, self._open())
  File "/usr/local/lib/python2.7/logging/__init__.py", line 936, in _open
    stream = open(self.baseFilename, self.mode)
IOError: [Errno 13] Permission denied: '/opt/cmx/var/log/cmxjobs.log'
With root I don't get any error now.
Is there any other way of doing this unattended backup?
Thanks.
Best regards,
Carolina
Highlighted
Hi Carolina,
Let me check with the CMX Developers for advise.  I will follow up soon.
Matt
Highlighted
Hi Carolina,
I found this for CMX 10.3 support case.  Hopefully this helps.
To retrieve the data for 1 day at a time.
Thus this script will loop through the days of June and produce and output file for each day of the month.  It looks like some of the days of June are already empty as we only keep 30 days of data.
for day in $(seq 1 30);do
  start=`date --date="$day-JUN-17" +%s`
  end=$((${start} + 86400))
  output_file="Jun$day-${start}000to${end}000.txt"
  echo "Processing $output_file"
  /opt/apache-cassandra-2.1.13/bin/cqlsh --request-timeout=300 cassandra.service.consul -e "select * from loc.hist_mob where changedon >${start}000 and changedon <${end}000 allow filtering" > /tmp/${output_file}
done
I create /home/cmxadmin/june.sh to wrap the logic above.  Since it would run quite a while, it would be good to run like this:
nohup /home/cmxadmin/june.sh &
The output files could be found in the /tmp directory.
I hope this helps.
Highlighted
Beginner
Is it me or does this reply have nothing to do with the question of how to automate the call to "cmxos backup --all --path /tmp --offline" ?
Highlighted
Hi ccoqutnoc,
Please see https://www.cisco.com/c/en/us/td/docs/wireless/mse/10-5/cmx_config/b_cg_cmx105/performing_administrative_tasks.html
for the following procedure to be added as a cron entry.
Thanks.
Highlighted
Beginner
This is extremely unhelpful. Did you read the doco ? It doesn't outline using ftp, it says to allocate a NAS mount.
Running the "cmxos backup ..." works when you are logged in, but scripting that ? Forget it. You end up with the error the original poster listed on v10.4 CMX.
Using FTP Commands for Cisco CMX
You can use File Transfer Protocol (FTP) commands for backing up and restoring data on Cisco CMX 10.x. We recommend you to follow the below best practice for data backup automation:
Procedure
________________________________
Step 1
Setup a NAS Storage and mount it to your Cisco CMX box, for example, mount the storage to a local directory such as /mnt/nas.
Highlighted
Beginner
If you are able to advise how to get the cmxos inside a #!/bin/sh call that’d be great.
This is the script I would be using but for the issue that cmxos fails when not run on an interactive ssh connection.
Autocreation script for data: ~/FTPbackup.sh
#!/bin/sh
SERVER=server
USER=user
PASS=password
WORKDIR=~/backups
#Move to working directory
mkdir -p $WORKDIR 2>/dev/null
cd $WORKDIR
if [ -r ~/FTPbackup.lock ]
then
echo "Lock file present, go see what didn't terminate in `host` cmxadmin ~/FTPbackup.lastRunLog"
exit
else
touch ~/FTPbackup.lock
echo "" > ~/FTPbackup.lastRunLog
fi
echo "lcd /tmp
cd cmx
binary
put `ls -1t cmx_backup* | head -n 1`
bye
" > ~/ftp-upload
echo "machine $SERVER
login $USER
password $PASS
" > ~/.netrc
echo "yes
" >~/yes
chmod 600 ~/.netrc
ls -1tr cmx_backup* | head -n -3 | xargs -d '\n' rm -f --
#/opt/cmx/bin/cmxos backup --all --path $WORKDIR --offline < ~/yes >>~/FTPbackup.lastRunLog 2>>~/FTPbackup.lastRunLog
/opt/cmx/bin/cmxos backup -i conf --path $WORKDIR --online >>~/FTPbackup.lastRunLog 2>>~/FTPbackup.lastRunLog
/usr/bin/ftp -i $SERVER < ~/ftp-upload >>~/FTPbackup.lastRunLog 2>>~/FTPbackup.lastRunLog
#Clear run flag
/bin/rm -f ~/FTPbackup.lock
$ cat FTPbackup.lastRunLog
__import__(pkg)
File "/opt/cmx/sw/lib/pymodules/cmxos/__init__.py", line 7, in <module>
from cmxos import CMXOS
File "/opt/cmx/sw/lib/pymodules/cmxos/cmxos.py", line 36, in <module>
from cmxagent.util.prettyfmt import print_pretty_table
import cmxjobs
Local directory now /tmp
(local-file) usage: put local-file remote-file
Highlighted
Beginner
Also, as originally mentioned the command is not able to execute inside the shell, there are missing environment possibly. Running a 'set' command give variables but also a heap of functions that are not present in a /bin/sh environment.
I am able to automate the FTP upload myself, but getting the backup script to function inside a shell script is not working.
My test case:
[cmxadmin@itn-cmx02 ~]$ cat /home/cmxadmin/backup-cmx.sh
#!/bin/sh
cd /tmp
cmxos backup -i conf --path /tmp --online
[cmxadmin@itn-cmx02 ~]$ /home/cmxadmin/backup-cmx.sh
__import__(pkg)
import cmxjobs
Highlighted
Beginner
#!/bin/sh
SERVER=server
USER=user
PASS=password
WORKDIR=~/backups
cd $WORKDIR
then
        exit
else
fi
echo "lcd /tmp
cd cmx
binary
bye
" > ~/ftp-upload
        login $USER
        password $PASS
" > ~/.netrc
echo "yes
" >~/yes
chmod 600 ~/.netrc
#Clear run flag
    __import__(pkg)
    import cmxjobs
Highlighted
CMX documentation indicate that it's possible to use FTP to extract a backup from the appliance. CMX does not have support for FTP as of 10.2.  There is a bug report CSCuz66206 to remove using ftp for backup in the CMX config guide.  The Workaround: use SCP copy
Thanks.
Highlighted
Beginner
Re: CMX backup automation - FTP solution
Here is how I have it working. The cmxos will not run inside a script due to other environment variables missing. So here is how I have it working, with FTP and installed to crontab:
#!/bin/sh
# Cisco CMX crontab backup to FTP server
# Antony Somerville 7/August/2018
# install into /home/cmxadmin and crontab execute for 'cmxadmin' user:
# 0 1 * * * 0 /home/cmxadmin/cmx_backup.sh
SERVER=servername
USER=username
PASS=userpasswd
# use /tmp or the DB dump fails
WORKDIR=/tmp
#<start .bashrc> pull this from the ~/.bashrc
# Auto complete files created for CMX commands, creates
# the environment to allow cmxos to run
. /etc/bash_completion.d/cmxctl.bash
. /etc/bash_completion.d/cmxha.bash
. /etc/bash_completion.d/cmxos.bash
. /etc/bash_completion.d/cmxloc.bash
alias cmxctl='sudo -u cmx /opt/cmx/bin/cmxctl --prompt'
alias cmxloc='sudo -u cmx /opt/cmx/bin/cmxloc'
alias cmxha='sudo -u cmxadmin /opt/cmx/bin/cmxha'
alias proxyctl='sudo -u cmx /opt/cmx/bin/proxyctl'
alias nodesetup='sudo -u cmx /opt/cmx/bin/nodesetup'
alias cmxos='sudo -u root /opt/cmx/bin/cmxos'
alias cmxverify='sudo -u root /opt/cmx/bin/cmxverify'
#<end .bashrc>
cd $WORKDIR
then
exit
else
fi
login $USER
password $PASS
" > ~/.netrc
echo "yes
" >~/yes
chmod 600 ~/.netrc
ls -1tr cmx_backup* 2>/dev/null | head -n -3 | xargs -d '\n' rm -f --
#mini backup for testing purposes
#cmxos backup -i conf --path $WORKDIR --online >>~/FTPbackup.lastRunLog 2>>~/FTPbackup.lastRunLog
echo "lcd $WORKDIR
cd cmx
binary
bye
" > ~/ftp-upload
#Clear run flag
Highlighted
Beginner
Hi ccoqutnoc,
Thanks for the script.
Manually executing the script works perfectly but when executed via crontab, nothing happens.
It seems a permission issue with crontab.
Did you modify something to have your script working on your appliance?
Sylvain.
Highlighted
Beginner
Finally found my issue.
Backup are working fine now.
Sylvain.
Content for Community-Ad
Cisco Community May 2020 Spotlight Award Winners
