Highlighted
Beginner
Re: CMX backup automation - FTP solution
I am in the same situation. The script works fine when I run it but it is not running via cron. It seems to be a permission issue.
How did you solve your problem?
Victor
Highlighted
Beginner
Hello @rhobab
I finally wrote another script based on the one provided in this topic.
I'm executing this script in a crontab with the root user. Maybe not the best solution but this is the only working solution I found.
[root@cmx ~]# cat backup-cmx.sh
#!/bin/bash
PATH=/usr/local/bin:/usr/java/latest/bin:/opt/cmx/bin:/usr/pgsql-9.3/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
#<start .bashrc> pull this from the ~/.bashrc
# Auto complete files created for CMX commands, creates
# the environment to allow cmxos to run
. /etc/bash_completion.d/cmxctl.bash
. /etc/bash_completion.d/cmxha.bash
. /etc/bash_completion.d/cmxos.bash
. /etc/bash_completion.d/cmxloc.bash
alias cmxctl='sudo -u cmx /opt/cmx/bin/cmxctl --prompt'
alias cmxloc='sudo -u cmx /opt/cmx/bin/cmxloc'
alias cmxha='sudo -u cmxadmin /opt/cmx/bin/cmxha'
alias proxyctl='sudo -u cmx /opt/cmx/bin/proxyctl'
alias nodesetup='sudo -u cmx /opt/cmx/bin/nodesetup'
alias cmxos='sudo -u root /opt/cmx/bin/cmxos'
alias cmxverify='sudo -u root /opt/cmx/bin/cmxverify'
#<end .bashrc>
#Backup file will be saved to /tmp/
#Define username and password
USERNAME="xxx"
PASSWORD="xxx"
#Backup CMX appliance without stopping CMX services
echo "-----> Backup CMX without stopping CMX services"
cmxos backup --all --online --path /tmp/
#Upload backup files to remote directory via FTP
REMOTE_FTP="ftp://x.x.x.x/"
echo "-----> Remote server is: "$REMOTE_FTP
#Check if backup file has been created under /tmp/
echo "-----> Following backup file has been created under /tmp/: "
ls /tmp/cmx_backup_*
#Transfer backup file to remote FTP server
echo "-----> Backup transfer starting..."
curl -T /tmp/cmx_backup_* ${REMOTE_FTP} --user "${USERNAME}:${PASSWORD}"
echo "-----> Backup transfer ended..."
echo "-----> Removing local backup files to free up disk space"
rm -f /tmp/cmx_backup_*
echo "-----> Backup file has been locally deleted."
#EOF
[root@cmx ~]#
Sylvain.
Highlighted
Beginner
I have been able to get it working with the other script. I scheduled it via crontab as root, then deleted the schedule and scheduled it again as cmxadmin and it started working.
Content for Community-Ad
Cisco Community July 2020 Spotlight Award Winners
