Highlighted
Beginner
MSE Location : pb with getTagInfoList
I am using a MSE 7.4.110.0 and the wsdl 7.4 available here.
I have loaded the wsdl in my java application with Apache CXF.
When I am using the getTagInfoList from location API, Apache CXF provide me an error :
Caused by: javax.xml.bind.UnmarshalException: élément inattendu (URI : "http://cisco.com/mse/location", local : "AesDefaultTelemMeasurement"). Les éléments attendus sont <{http://cisco.com/mse/location}measurement>
    at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext.handleEvent(UnmarshallingContext.java:662)
    at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:258)
    at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportError(Loader.java:253)
    at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.reportUnexpectedChildElement(Loader.java:120)
    at com.sun.xml.bind.v2.runtime.unmarshaller.Loader.childElement(Loader.java:105)
    at com.sun.xml.bind.v2.runtime.unmarshaller.StructureLoader.childElement(StructureLoader.java:262)
    at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext._startElement(UnmarshallingContext.java:498)
    at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallingContext.startElement(UnmarshallingContext.java:480)
    at com.sun.xml.bind.v2.runtime.unmarshaller.StAXStreamConnector.handleStartElement(StAXStreamConnector.java:246)
    at com.sun.xml.bind.v2.runtime.unmarshaller.StAXStreamConnector.bridge(StAXStreamConnector.java:180)
    at com.sun.xml.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:370)
In my code, i am doing this :
final GetListArgs getListArgs = new GetListArgs();
getListArgs.setAesBusinessSession(session.getAesBusinessSession());
final AesQueryCriteria aesQueryCriteria = new AesQueryCriteria();
aesQueryCriteria.setStartIndex(startIndex);
aesQueryCriteria.setNumOfResults(1000);
getListArgs.setAesQueryCriteria(aesQueryCriteria);
final Response response = this.mseLocation.getTagInfoList(getListArgs);
AesQueryCriteria has been defined follwing the example of MSE Mobility Services API Specification(version 7.4).pdf
Page 110, look for getTagInfoList with the soap request for get all tag define in the MSE
I have also intercept the soap messages exchanged :
Request :
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
    <soap:Body>
        <ns2:GetTagInfoList xmlns="http://cisco.com/mse/types" xmlns:ns2="http://cisco.com/mse/location">
            <AesBusinessSession id="30292" objectId="0" parentId="0" changedOn="0" mask="-1" options="0"/>
            <AesQueryCriteria startIndex="0" numOfResults="1000"/>
        </ns2:GetTagInfoList>
    </soap:Body>
</soap:Envelope>
Response :
<?xml version='1.0' encoding='UTF-8'?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
    <SOAP-ENV:Body>
        <Response xmlns="http://cisco.com/mse/location">
            <AesTag batteryStatus="3" changedOn="1398321597464" lastBeaconSeqNum="3814" lastBeaconTime="0" macAddress="00:04:f1:53:d5:08" objectId="1">
                <asset>
                    <AesAsset assetGroup="myGroup" assetName="btn1" />
                </asset>
                <batteryInfo>
                    <AesBatteryInfo batteryAge="652" daysRemaining="1174" lastReceivedSeqNum="3814" lastReceivedTime="1398321596141" percentRemaining="60" tolerance="20" />
                </batteryInfo>
                <telemetryList>
                    <AesTelemetry changedOn="1397742692002" lastReceivedSeqNum="3653" lastReceivedTime="1397742691131" measurementClass="com.aes.datamodel.location.ctx.AesDefaultTelemMeasurement" objectId="615" parentId="1" type="STATUS">
                        <AesDefaultTelemMeasurement measurementClass="java.lang.String" measurementObj="0,50," />
                        <objectId mask="0,50," parentId="java.lang.String" />
                    </AesTelemetry>
                </telemetryList>
            </AesTag>
            <AesTag batteryStatus="2" changedOn="1398317602766" debug="true" lastBeaconSeqNum="150" lastBeaconTime="0" macAddress="00:0c:cc:78:57:6d" objectId="7">
                <asset>
                    <AesAsset assetGroup="myGroup" assetName="btn2" />
                </asset>
                <batteryInfo>
                    <AesBatteryInfo lastReceivedSeqNum="150" lastReceivedTime="1398317601655" percentRemaining="80" tolerance="20" />
                </batteryInfo>
                <vendorData>
                    <AesVendorData changedOn="1398317602768" data="0,0,9,0," lastReceivedSeqNum="150" lastReceivedTime="1398317601655" objectId="3877" parentId="7" vendorId="3276" />
                </vendorData>
                <emergencyList>
                    <AesEmergency changedOn="1398317602767" isActive="false" lastReceivedSeqNum="143" lastReceivedTime="1398238110241" objectId="2435" parentId="7" />
                    <AesEmergency changedOn="1398317602767" isActive="false" lastReceivedSeqNum="93" lastReceivedTime="1397655583405" objectId="2434" parentId="7" />
                    <AesEmergency changedOn="1398317602767" isActive="false" lastReceivedSeqNum="89" lastReceivedTime="1397630356048" objectId="2432" parentId="7" />
                    <AesEmergency changedOn="1398317602767" isActive="false" lastReceivedSeqNum="77" lastReceivedTime="1397542694787" objectId="2431" parentId="7" />
                    <AesEmergency changedOn="1398317602767" isActive="false" lastReceivedSeqNum="66" lastReceivedTime="1397485308820" objectId="2424" parentId="7" />
                </emergencyList>
            </AesTag>
        </Response>
    </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
I don't understand for what I have this problem with the unmarshalling.
Thank youin advance for your help.
Cyrille
1 REPLY 1
Highlighted
Beginner
Re: MSE Location : pb with getTagInfoList
After some researches and test, it looks like that the part of the soap message which throw the error is with the tag <AesTelemetry>.
If the getTagListInfo return a soap message as follow :
    <SOAP-ENV:Body>
            <AesTag batteryStatus="3" changedOn="1398325205524" lastBeaconSeqNum="3815" lastBeaconTime="0" macAddress="00:04:f1:53:d5:08" objectId="1">
                <asset>
                    <AesAsset assetGroup="callbox-CYD" assetName="Grand Zebra" />
                </asset>
                <batteryInfo>
                    <AesBatteryInfo batteryAge="652" daysRemaining="1174" lastReceivedSeqNum="3815" lastReceivedTime="1398325204138" percentRemaining="60" tolerance="20" />
                </batteryInfo>
                <telemetryList>
                    </AesTelemetry>
                </telemetryList>
            </AesTag>
        </Response>
    </SOAP-ENV:Body>
this is this part which throw the error :
                    </AesTelemetry>
I have simulated the reponse of the MSE for that it provide a correct message.
The following message works :
    <SOAP-ENV:Body>
            <AesTag batteryStatus="3" changedOn="1398328757023" lastBeaconSeqNum="3819" lastBeaconTime="0" macAddress="00:04:f1:53:d5:08" objectId="1">
                <asset>
                </asset>
                <batteryInfo>
                    <AesBatteryInfo batteryAge="652" daysRemaining="1174" lastReceivedSeqNum="3819" lastReceivedTime="1398328755570" percentRemaining="60" tolerance="20" />
                </batteryInfo>
                <telemetryList>
                    <AesTelemetry changedOn="1398328665144" lastReceivedSeqNum="3818" lastReceivedTime="1398328663691" measurementClass="com.aes.datamodel.location.ctx.AesDefaultTelemMeasurement" objectId="672" parentId="1" type="STATUS">
                        <measurement>
                            <String />
                            <AesEPC />
                            <AesGeo />
                            <AesMotionProbability />
                        </measurement>
                    </AesTelemetry>
                </telemetryList>
            </AesTag>
        </Response>
    </SOAP-ENV:Body>
I have just modify this part :
                    </AesTelemetry>
by
                        <measurement>
                            <String />
                            <AesEPC />
                            <AesGeo />
                        </measurement>
                    </AesTelemetry>
and it works !
It looks like there is a problem with the soap message generated by the MSE with AesTelemetry  object or with the Wsdl / xsd 7.4.
I have found in the API spec this note :
Note: By default, the AesTelemetry object will include 2 child elements objectId and the AesDefaultTelemMeasurement. If the API user prefers to get only one of the above, there is a flag on the MSE which can be used to change which format needs to be included in the AesTelemetryObject. The old element is for backward compatibility.
If anybody knows how to modify this setting or has an idea for correct this problem, I take it.
Content for Community-Ad
Cisco Community July 2020 Spotlight Award Winners
