MSE Simulator does not start
482
Subject: RE: MSE Simulator does not start
Replied by: Raghavendra Gutty Veeranagappa on 18-06-2010 08:18:10 AM
Hi Maulik shah,
Please verify mse ip is configured as part of installation, configure parameters
by executing following command
cd /opt/mse/setup
./setup.sh
then try the following commands
/etc/init.d/msed stop
/etc/init.d/msed start
/etc/init.d/msed status
Raghavendra
<font size="2">
</font>
This document was generated from CDN thread
Created by: Maulik Shah on 18-06-2010 06:59:29 AM
I have downloaded and setup the MSE Simulator VM Image on a Windows XP machine. At startup, the simualtor keeps showing the message "Starting MSE Platform, waiting to check the status" and eventually dies out with the message "Failed to get the status". The msed status command returns "STATUS: MSE Platform is down". Explicitly starting through msed start also results in the same behaviour above.
Can someone please help resolve this?
Maulik Shah
Replied by: amlan dutta on 18-08-2010 07:14:12 AM
I have downloaded the MSE simulator and it works fine, I have also download the sample MSE Java applications, but failed to connect to the mobility service engine, as I have already added the axis2 jar and location jar and follow the instructions in read me. Can anyone tell me wheather we need WCS to connect to the mobility service engine or directly through sample application we can connect.
Amlan
Maulik Shah
Replied by: Matthew J Denapoli on 18-08-2010 01:02:46 PM
Hi Amlan,
No, you do not need WCS at all.  WCS is a wireless management tool that uses the context aware api, but it is not necessary to get the simulator up and running.  You can connect directly to the MSE from your sample application.
If you are having trouble with your code, please post the snippet and your MSE ifconfig.
Matt
Replied by: amlan dutta on 19-08-2010 05:57:49 AM
Thanks a lot.
My simulator is up and I can able to see the status and I can ping my MSE from my machine.
I have downloaded the Sample JAVA application available on the Cisco site. I have added all the jars and try to connect the MSE.
I am able to download the certificate but didnt able to connect the MSE, I have changed the ip address in Connecntion Constructor as MSE ip address
login name and password as admin.
but it seems getAesBusinessSession() function returing business session object as
NULL.
ifconfig of MSE is giving the result as follows
eth0   Link
encap:Ethernet  HWaddr 00:0C:29:92:709
          inet addr:192.168.49.2  Bcast:192.168.49.255
Mask:255.255.255.0
          inet6 addr: fe80::20C:29ff:fe92:70D9/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:222 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5515 errors:52 dropped:0 overruns:0 carrier:104
          collisions:0 txqueuelen:1000
          RX bytes:23418 (22.8 Ki  TX bytes:248237 (242.4 Ki
          Interrupt:19 Base address:0x2024
lo
Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:525800 errors:0 dropped:0 overruns:0 frame:0
          TX packets:525800 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:34812887 (33.2 Mi  TX bytes:34812887 (33.2Mib)
My log is as follows
18:08:20,533  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
18:09:22,952  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:09:22,959  INFO HttpMethodDirector:445 - Retrying request
18:09:45,716 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1342ba4named: {http://cisco.com/mse}Login
18:09:45,725 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1342ba4named: {http://cisco.com/mse}Login
18:09:45,726 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@8e32e7named: {http://cisco.com/mse}Logout
18:09:45,726 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@8e32e7named: {http://cisco.com/mse}Logout
18:09:45,761 DEBUG Loader:132 - Trying to find [org/apache/axis2/deployment/axis2_default.xml] using sun.misc.Launcher$AppClassLoader@601bb1 class loader.
18:09:45,795 DEBUG StAXUtils:333 - About to create XMLInputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:45,797 DEBUG StAXUtils:335 - The classloader for javax.xml.stream.XMLInputFactory is: null
18:09:45,862 DEBUG StAXUtils:382 - Created XMLInputFactory = class com.ctc.wstx.stax.WstxInputFactory with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:45,865 DEBUG StAXUtils:384 - Size of XMLInputFactory map =1
18:09:45,866 DEBUG StAXUtils:385 - isNetworkDetached =false
18:09:45,968 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
18:09:46,081 DEBUG OMNodeImpl:330 - Builder is already complete.
18:09:46,188 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Transport
18:09:46,196 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Transport
18:09:46,203 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
18:09:46,207 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
18:09:46,209 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
18:09:46,212 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
18:09:46,216 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
18:09:46,220 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
18:09:46,221 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
18:09:46,222 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
18:09:46,223 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
18:09:46,223 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
18:09:46,224 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
18:09:46,224 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
18:09:46,343 DEBUG RepositoryListener:145 - Deploying module from classpath at 'file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar'
18:09:46,521 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
18:09:46,528 DEBUG OMNodeImpl:330 - Builder is already complete.
18:09:46,572 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
18:09:46,611 DEBUG ProjectResourceBundle:412 - loadBundle: Ignoring MissingResourceException: Can't find bundle for base name org.apache.axis2.resource, locale en_IN
18:09:46,613 DEBUG ProjectResourceBundle:289 - Created org.apache.axis2.i18n.resource, linked to parent null
18:09:46,616 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
18:09:46,617 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(addingnewmodule)
18:09:46,620 DEBUG DeploymentEngine:553 - Adding new module
18:09:46,621 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(deployingmodule)
18:09:46,625  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
18:09:46,728 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService24585668]
18:09:46,860 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpEndpoint)
18:09:46,862 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpSoap11Endpoint)
18:09:46,864 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpSoap12Endpoint)
18:09:46,866 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 3
18:09:47,365 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1bbd7b2named: {http://cisco.com/mse}Login
18:09:47,367 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1bbd7b2named: {http://cisco.com/mse}Login
18:09:47,369 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@14df764named: {http://cisco.com/mse}Logout
18:09:47,369 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@14df764named: {http://cisco.com/mse}Logout
18:09:47,370 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService21830977]
18:09:47,374 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpEndpoint)
18:09:47,374 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpSoap11Endpoint)
18:09:47,377 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpSoap12Endpoint)
18:09:47,380 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 6
18:09:47,382 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
18:09:47,382 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@1bbd7b2
18:09:47,500 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1035079 with key: urn:uuid:F334FD6681A32633CF1282135187515
18:09:47,505 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
18:09:47,516 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
18:09:47,522 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1035079 with key: urn:uuid:F334FD6681A32633CF1282135187515
18:09:47,523 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] action: Login
18:09:47,534 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "OperationOutPhase"
18:09:47,537 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "OperationOutPhase"
18:09:47,539 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "OperationOutPhase"
18:09:47,539 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "RMPhase"
18:09:47,539 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "RMPhase"
18:09:47,540 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "RMPhase"
18:09:47,540 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "PolicyDetermination"
18:09:47,541 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "PolicyDetermination"
18:09:47,541 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "PolicyDetermination"
18:09:47,542 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "MessageOut"
18:09:47,542 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "MessageOut"
18:09:47,545 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "MessageOut"
18:09:47,545 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "Security"
18:09:47,545 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "Security"
18:09:47,546 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "Security"
18:09:47,691 DEBUG DefaultHttpParams:151 - Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
18:09:47,699 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.version = HTTP/1.1
18:09:47,708 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
18:09:47,710 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.cookie-policy = default
18:09:47,712 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.element-charset = US-ASCII
18:09:47,713 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.content-charset = ISO-8859-1
18:09:47,718 DEBUG DefaultHttpParams:151 - Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@160877b
18:09:47,723 DEBUG DefaultHttpParams:151 - Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
18:09:47,757 DEBUG HttpClient:72 - Java version: 1.6.0_20
18:09:47,760 DEBUG HttpClient:73 - Java vendor: Sun Microsystems Inc.
18:09:47,763 DEBUG HttpClient:74 - Java class path: /home/amlan/Downloads/MSE/java/bin:/home/amlan/Downloads/MSE/java/jars/aaaService-test-client-5.2.jar:/home/amlan/Downloads/MSE/java/jars/LocationService-test-client-5.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/activation-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-api-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-dom-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-impl-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-ant-plugin-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-clustering-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-corba-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-fastinfoset-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-java2wsdl-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxbri-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxws-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jibx-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-json-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-kernel-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-metadata-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-mtompolicy-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-saaj-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-spring-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-http-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-local-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-xmlbeans-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/bcel-5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-codec-1.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-fileupload-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-httpclient-3.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-io-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-lang-2.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-logging-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-annotation_1.0_spec-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-jaxws_2.1_spec-1.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-saaj_1.3_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-stax-api_1.0_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-ws-metadata_2.0_spec-1.1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/httpcore-4.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jalopy-1.5rc3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-api-2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-impl-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-xjc-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxen-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jettison-1.0-RC2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-bind-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-run-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/log4j-1.2.15.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mail-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/neethi-2.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smack-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smackx-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/soapmonitor-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-api-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-impl-dom-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wsdl4j-1.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wstx-asl-3.2.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xalan-2.7.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xercesImpl-2.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-apis-1.3.02.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xmlbeans-2.3.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-resolver-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/XmlSchema-1.4.3.jar
18:09:47,765 DEBUG HttpClient:75 - Operating system name: Linux
18:09:47,766 DEBUG HttpClient:76 - Operating system architecture: i386
18:09:47,767 DEBUG HttpClient:77 - Operating system version: 2.6.32-21-generic
18:09:48,008 DEBUG HttpClient:82 - SUN 1.6: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
18:09:48,010 DEBUG HttpClient:82 - SunRsaSign 1.5: Sun RSA signature provider
18:09:48,011 DEBUG HttpClient:82 - SunJSSE 1.6: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
18:09:48,012 DEBUG HttpClient:82 - SunJCE 1.6: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
18:09:48,013 DEBUG HttpClient:82 - SunJGSS 1.0: Sun (Kerberos v5, SPNEGO)
18:09:48,014 DEBUG HttpClient:82 - SunSASL 1.5: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
18:09:48,015 DEBUG HttpClient:82 - XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
18:09:48,017 DEBUG HttpClient:82 - SunPCSC 1.6: Sun PC/SC provider
18:09:48,046 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.timeout = 30000
18:09:48,052 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
18:09:48,053 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:09:48,054 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:09:48,101 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,103 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,104 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
18:09:48,104 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
18:09:48,195 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
18:09:48,204 DEBUG MultiThreadedHttpConnectionManager:760 - Allocating new connection, hostConfig=HostConfiguration
18:09:48,228 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:09:48,889 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:09:48,896 DEBUG HttpMethodBase:1352 - Adding Host request header
18:09:48,917 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:09:48,919 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:09:48,919 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:09:48,920 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:09:48,920 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:09:48,921 DEBUG header:70 - >> "[\r][\n]"
18:09:48,922 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:09:48,922 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:09:48,923 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:09:48,923 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:09:48,924 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:09:48,929 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:09:48,932 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,933 DEBUG StAXUtils:452 - About to create XMLOutputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:48,933 DEBUG StAXUtils:454 - The classloader for javax.xml.stream.XMLOutputFactory is: null
18:09:48,984 DEBUG StAXUtils:500 - Created XMLOutputFactory = class com.ctc.wstx.stax.WstxOutputFactory for classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:48,986 DEBUG StAXUtils:502 - Size of XMLOutputFactory map =1
18:09:49,003 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:09:49,024 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
18:10:19,143 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:10:19,145 DEBUG HttpMethodDirector:404 - Closing the connection.
18:10:49,175  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:10:49,180 DEBUG HttpMethodDirector:443 - Read timed out
org.apache.axis2.AxisFault: Read timed out
    at org.apache.axis2.AxisFault.makeFault(AxisFault.java:430)
    at org.apache.axis2.transport.http.SOAPMessageFormatter.writeTo(SOAPMessageFormatter.java:83)
    at org.apache.axis2.transport.http.AxisRequestEntity.writeRequest(AxisRequestEntity.java:84)
    at org.apache.commons.httpclient.methods.EntityEnclosingMethod.writeRequestBody(EntityEnclosingMethod.java:499)
    at org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2114)
    at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1096)
    at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
    at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
    at org.apache.axis2.transport.http.AbstractHTTPSender.executeMethod(AbstractHTTPSender.java:542)
    at org.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.java:199)
    at org.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:76)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessageWithCommons(CommonsHTTPTransportSender.java:400)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(CommonsHTTPTransportSender.java:225)
    at org.apache.axis2.engine.AxisEngine.send(AxisEngine.java:435)
    at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:402)
    at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
    at org.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
    at com.cisco.mse.AaaServiceStub.Login(AaaServiceStub.java:148)
    at com.cisco.mse.aaa.Connection.Login(Connection.java:86)
    at com.cisco.mse.aaa.Connection.main(Connection.java:53)
Caused by: com.ctc.wstx.exc.WstxIOException: Read timed out
    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)
    at org.apache.axiom.om.impl.MTOMXMLStreamWriter.flush(MTOMXMLStreamWriter.java:168)
    at org.apache.axiom.om.impl.llom.OMNodeImpl.serializeAndConsume(OMNodeImpl.java:487)
    at org.apache.axis2.transport.http.SOAPMessageFormatter.writeTo(SOAPMessageFormatter.java:79)
    ... 20 more
Caused by: java.net.SocketTimeoutException: Read timed out
    at java.net.SocketInputStream.socketRead0(Native Method)
    at java.net.SocketInputStream.read(SocketInputStream.java:129)
    at com.sun.net.ssl.internal.ssl.InputRecord.readFully(InputRecord.java:293)
    at com.sun.net.ssl.internal.ssl.InputRecord.read(InputRecord.java:331)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:789)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1120)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:623)
    at com.sun.net.ssl.internal.ssl.AppOutputStream.write(AppOutputStream.java:59)
    at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
    at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
    at java.io.FilterOutputStream.flush(FilterOutputStream.java:123)
    at org.apache.commons.httpclient.ChunkedOutputStream.flush(ChunkedOutputStream.java:191)
    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:99)
    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)
    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)
    ... 23 more
18:10:49,197  INFO HttpMethodDirector:445 - Retrying request
18:10:49,197 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:10:49,200 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:10:49,201 DEBUG HttpMethodBase:1352 - Adding Host request header
18:10:49,201 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:10:49,202 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:10:49,203 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:10:49,204 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:10:49,204 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:10:49,205 DEBUG header:70 - >> "[\r][\n]"
18:10:49,209 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:10:49,209 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:10:49,210 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:10:49,210 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:10:49,211 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:10:49,212 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:10:49,212 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:10:49,214 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:10:49,216 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:10:49,222 DEBUG HttpMethodDirector:404 - Closing the connection.
18:11:19,461  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
18:11:19,461 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
org.apache.axis2.AxisFault: problem accessing the parser. Parser already accessed!
Caused by: javax.xml.stream.XMLStreamException: problem accessing the parser. Parser already accessed!
    at org.apache.axiom.om.impl.llom.OMStAXWrapper.next(OMStAXWrapper.java:983)
    at org.apache.axiom.om.util.OMXMLStreamReaderValidator.next(OMXMLStreamReaderValidator.java:76)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serializeNode(StreamingOMSerializer.java:125)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serialize(StreamingOMSerializer.java:93)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serialize(StreamingOMSerializer.java:76)
    at org.apache.axiom.om.impl.util.OMSerializerUtil.serializeByPullStream(OMSerializerUtil.java:579)
    at org.apache.axiom.om.impl.llom.OMElementImpl.internalSerialize(OMElementImpl.java:970)
    at org.apache.axiom.om.impl.llom.OMElementImpl.internalSerializeAndConsume(OMElementImpl.java:995)
    at org.apache.axiom.soap.impl.llom.SOAPEnvelopeImpl.serializeInternally(SOAPEnvelopeImpl.java:254)
    at org.apache.axiom.soap.impl.llom.SOAPEnvelopeImpl.internalSerialize(SOAPEnvelopeImpl.java:242)
    at org.apache.axiom.om.impl.llom.OMNodeImpl.serializeAndConsume(OMNodeImpl.java:486)
    ... 20 more
Caused by: java.lang.IllegalStateException: Parser already accessed!
    at org.apache.axiom.om.impl.builder.StAXBuilder.getParser(StAXBuilder.java:508)
    at org.apache.axiom.om.impl.llom.OMStAXWrapper.next(OMStAXWrapper.java:981)
    ... 32 more
18:11:19,465  INFO HttpMethodDirector:445 - Retrying request
18:11:19,466 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:11:19,476 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:11:19,478 DEBUG HttpMethodBase:1352 - Adding Host request header
18:11:19,479 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:11:19,480 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:11:19,482 DEBUG header:70 - >> "[\r][\n]"
18:11:19,482 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:11:19,482 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:11:19,483 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:11:19,483 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:11:19,483 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:11:19,484 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:11:19,484 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:19,485 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:11:19,486 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:11:19,486 DEBUG HttpMethodDirector:457 - Closing the connection.
18:11:49,524 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
18:11:49,524 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
18:11:49,525 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282135309525
18:11:49,525 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
18:11:49,542 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@633d51named: {http://cisco.com/mse}Login
18:11:49,543 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@633d51named: {http://cisco.com/mse}Login
18:11:49,544 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@14eaec9named: {http://cisco.com/mse}Logout
18:11:49,544 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@14eaec9named: {http://cisco.com/mse}Logout
18:11:49,545 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService9715140]
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpSoap11Endpoint)
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpSoap12Endpoint)
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpEndpoint)
18:11:49,547 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 9
18:11:49,547 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
18:11:49,547 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@633d51
18:11:49,548 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@b533b8 with key: urn:uuid:F334FD6681A32633CF1282135309572
18:11:49,548 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
18:11:49,548 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
18:11:49,549 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@b533b8 with key: urn:uuid:F334FD6681A32633CF1282135309572
18:11:49,549 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] action: Login
18:11:49,549 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "RMPhase"
18:11:49,550 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "RMPhase"
18:11:49,551 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "RMPhase"
18:11:49,559 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "PolicyDetermination"
18:11:49,560 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "PolicyDetermination"
18:11:49,560 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "PolicyDetermination"
18:11:49,561 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "MessageOut"
18:11:49,561 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "MessageOut"
18:11:49,561 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "MessageOut"
18:11:49,562 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "Security"
18:11:49,562 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "Security"
18:11:49,563 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "Security"
18:11:49,564 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
18:11:49,565 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:11:49,566 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,566 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,567 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
18:11:49,567 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
18:11:49,571 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
18:11:49,572 DEBUG MultiThreadedHttpConnectionManager:839 - Getting free connection, hostConfig=HostConfiguration
18:11:49,573 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:11:49,575 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:11:49,576 DEBUG HttpMethodBase:1352 - Adding Host request header
18:11:49,577 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:11:49,578 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:11:49,578 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:11:49,579 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:11:49,583 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:11:49,583 DEBUG header:70 - >> "[\r][\n]"
18:11:49,584 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:11:49,585 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:11:49,585 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:11:49,586 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:11:49,586 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:11:49,586 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:11:49,587 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,587 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:11:49,588 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
18:12:19,624 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:12:19,625 DEBUG HttpMethodDirector:404 - Closing the connection.
18:12:49,655  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:12:49,656 DEBUG HttpMethodDirector:443 - Read timed out
    at com.cisco.mse.aaa.Connection.main(Connection.java:54)
    ... 20 more
    ... 23 more
18:12:49,657  INFO HttpMethodDirector:445 - Retrying request
18:12:49,657 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:12:49,678 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:12:49,678 DEBUG HttpMethodBase:1352 - Adding Host request header
18:12:49,679 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:12:49,680 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:12:49,681 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:12:49,685 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:12:49,686 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:12:49,687 DEBUG header:70 - >> "[\r][\n]"
18:12:49,688 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:12:49,692 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:12:49,694 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:12:49,694 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:12:49,696 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:12:49,697 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:12:49,698 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:12:49,699 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:12:49,700 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:12:49,702 DEBUG HttpMethodDirector:404 - Closing the connection.
18:13:19,741  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
18:13:19,754 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
18:13:19,780  INFO HttpMethodDirector:445 - Retrying request
18:13:19,780 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:13:19,783 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:13:19,784 DEBUG HttpMethodBase:1352 - Adding Host request header
18:13:19,785 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:13:19,786 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:13:19,787 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:13:19,788 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:13:19,789 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:13:19,789 DEBUG header:70 - >> "[\r][\n]"
18:13:19,790 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:13:19,792 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:13:19,794 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:13:19,795 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:13:19,796 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:13:19,796 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:13:19,796 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:13:19,797 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:13:19,806 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:13:19,806 DEBUG HttpMethodDirector:457 - Closing the connection.
18:13:50,068 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
18:13:50,069 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
18:13:50,069 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282135430069
18:13:50,069 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
10:07:07,422 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1d332bnamed: {http://cisco.com/mse}Login
10:07:07,477 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1d332bnamed: {http://cisco.com/mse}Login
10:07:07,478 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@1b000e7named: {http://cisco.com/mse}Logout
10:07:07,479 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@1b000e7named: {http://cisco.com/mse}Logout
10:07:07,579 DEBUG Loader:132 - Trying to find [org/apache/axis2/deployment/axis2_default.xml] using sun.misc.Launcher$AppClassLoader@601bb1 class loader.
10:07:07,630 DEBUG StAXUtils:333 - About to create XMLInputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:07,633 DEBUG StAXUtils:335 - The classloader for javax.xml.stream.XMLInputFactory is: null
10:07:07,736 DEBUG StAXUtils:382 - Created XMLInputFactory = class com.ctc.wstx.stax.WstxInputFactory with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:07,738 DEBUG StAXUtils:384 - Size of XMLInputFactory map =1
10:07:07,739 DEBUG StAXUtils:385 - isNetworkDetached =false
10:07:07,877 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
10:07:08,010 DEBUG OMNodeImpl:330 - Builder is already complete.
10:07:08,203 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Transport
10:07:08,213 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Transport
10:07:08,257 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
10:07:08,261 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
10:07:08,264 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
10:07:08,269 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
10:07:08,273 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
10:07:08,277 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
10:07:08,278 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
10:07:08,279 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
10:07:08,282 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
10:07:08,283 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
10:07:08,284 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
10:07:08,285 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
10:07:08,372 DEBUG RepositoryListener:145 - Deploying module from classpath at 'file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar'
10:07:08,544 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
10:07:08,548 DEBUG OMNodeImpl:330 - Builder is already complete.
10:07:08,573 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
10:07:08,599 DEBUG ProjectResourceBundle:412 - loadBundle: Ignoring MissingResourceException: Can't find bundle for base name org.apache.axis2.resource, locale en_IN
10:07:08,601 DEBUG ProjectResourceBundle:289 - Created org.apache.axis2.i18n.resource, linked to parent null
10:07:08,603 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
10:07:08,605 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(addingnewmodule)
10:07:08,607 DEBUG DeploymentEngine:553 - Adding new module
10:07:08,608 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(deployingmodule)
10:07:08,609  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
10:07:08,713 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService22048196]
10:07:08,890 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpEndpoint)
10:07:08,896 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpSoap11Endpoint)
10:07:08,897 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpSoap12Endpoint)
10:07:08,898 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 3
10:07:09,775 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@55bb93named: {http://cisco.com/mse}Login
10:07:09,777 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@55bb93named: {http://cisco.com/mse}Login
10:07:09,778 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@8de462named: {http://cisco.com/mse}Logout
10:07:09,778 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@8de462named: {http://cisco.com/mse}Logout
10:07:09,780 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService22927632]
10:07:09,783 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpSoap12Endpoint)
10:07:09,784 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpSoap11Endpoint)
10:07:09,784 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpEndpoint)
10:07:09,789 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 6
10:07:09,791 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
10:07:09,791 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@55bb93
10:07:09,954 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@983d95 with key: urn:uuid:A73FA32EA86E5B916D1282192629970
10:07:09,956 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
10:07:09,963 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
10:07:09,970 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@983d95 with key: urn:uuid:A73FA32EA86E5B916D1282192629970
10:07:09,972 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] action: Login
10:07:09,982 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "OperationOutPhase"
10:07:09,983 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "OperationOutPhase"
10:07:09,984 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "OperationOutPhase"
10:07:09,984 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "RMPhase"
10:07:09,985 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "RMPhase"
10:07:09,985 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "RMPhase"
10:07:09,985 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "PolicyDetermination"
10:07:09,985 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "PolicyDetermination"
10:07:09,986 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "PolicyDetermination"
10:07:09,986 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "MessageOut"
10:07:09,986 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "MessageOut"
10:07:09,988 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "MessageOut"
10:07:09,989 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "Security"
10:07:09,989 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "Security"
10:07:09,989 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "Security"
10:07:10,078 DEBUG DefaultHttpParams:151 - Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
10:07:10,082 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.version = HTTP/1.1
10:07:10,085 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
10:07:10,086 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.cookie-policy = default
10:07:10,086 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.element-charset = US-ASCII
10:07:10,087 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.content-charset = ISO-8859-1
10:07:10,092 DEBUG DefaultHttpParams:151 - Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@5eb489
10:07:10,094 DEBUG DefaultHttpParams:151 - Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
10:07:10,105 DEBUG HttpClient:72 - Java version: 1.6.0_20
10:07:10,107 DEBUG HttpClient:73 - Java vendor: Sun Microsystems Inc.
10:07:10,108 DEBUG HttpClient:74 - Java class path: /home/amlan/Downloads/MSE/java/bin:/home/amlan/Downloads/MSE/java/jars/aaaService-test-client-5.2.jar:/home/amlan/Downloads/MSE/java/jars/LocationService-test-client-5.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/activation-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-api-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-dom-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-impl-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-ant-plugin-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-clustering-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-corba-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-fastinfoset-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-java2wsdl-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxbri-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxws-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jibx-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-json-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-kernel-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-metadata-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-mtompolicy-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-saaj-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-spring-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-http-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-local-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-xmlbeans-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/bcel-5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-codec-1.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-fileupload-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-httpclient-3.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-io-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-lang-2.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-logging-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-annotation_1.0_spec-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-jaxws_2.1_spec-1.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-saaj_1.3_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-stax-api_1.0_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-ws-metadata_2.0_spec-1.1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/httpcore-4.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jalopy-1.5rc3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-api-2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-impl-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-xjc-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxen-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jettison-1.0-RC2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-bind-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-run-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/log4j-1.2.15.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mail-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/neethi-2.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smack-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smackx-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/soapmonitor-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-api-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-impl-dom-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wsdl4j-1.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wstx-asl-3.2.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xalan-2.7.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xercesImpl-2.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-apis-1.3.02.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xmlbeans-2.3.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-resolver-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/XmlSchema-1.4.3.jar
10:07:10,108 DEBUG HttpClient:75 - Operating system name: Linux
10:07:10,109 DEBUG HttpClient:76 - Operating system architecture: i386
10:07:10,109 DEBUG HttpClient:77 - Operating system version: 2.6.32-21-generic
10:07:10,437 DEBUG HttpClient:82 - SUN 1.6: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
10:07:10,439 DEBUG HttpClient:82 - SunRsaSign 1.5: Sun RSA signature provider
10:07:10,439 DEBUG HttpClient:82 - SunJSSE 1.6: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
10:07:10,439 DEBUG HttpClient:82 - SunJCE 1.6: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
10:07:10,440 DEBUG HttpClient:82 - SunJGSS 1.0: Sun (Kerberos v5, SPNEGO)
10:07:10,440 DEBUG HttpClient:82 - SunSASL 1.5: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
10:07:10,441 DEBUG HttpClient:82 - XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
10:07:10,441 DEBUG HttpClient:82 - SunPCSC 1.6: Sun PC/SC provider
10:07:10,459 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.timeout = 30000
10:07:10,463 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
10:07:10,464 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:07:10,465 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:07:10,485 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:10,487 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:10,488 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
10:07:10,488 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
10:07:10,530 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
10:07:10,534 DEBUG MultiThreadedHttpConnectionManager:760 - Allocating new connection, hostConfig=HostConfiguration
10:07:10,546 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:07:11,589 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:07:11,595 DEBUG HttpMethodBase:1352 - Adding Host request header
10:07:11,624 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:07:11,625 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:07:11,626 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:07:11,627 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:07:11,627 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:07:11,628 DEBUG header:70 - >> "[\r][\n]"
10:07:11,629 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:07:11,630 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:07:11,630 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:07:11,630 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:07:11,631 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:07:11,637 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:07:11,639 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:11,640 DEBUG StAXUtils:452 - About to create XMLOutputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:11,641 DEBUG StAXUtils:454 - The classloader for javax.xml.stream.XMLOutputFactory is: null
10:07:11,681 DEBUG StAXUtils:500 - Created XMLOutputFactory = class com.ctc.wstx.stax.WstxOutputFactory for classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:11,683 DEBUG StAXUtils:502 - Size of XMLOutputFactory map =1
10:07:11,707 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:07:11,732 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
10:07:42,234 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:07:42,236 DEBUG HttpMethodDirector:404 - Closing the connection.
10:08:12,264  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
10:08:12,268 DEBUG HttpMethodDirector:443 - Read timed out
    ... 20 more
    ... 23 more
10:08:12,274  INFO HttpMethodDirector:445 - Retrying request
10:08:12,277 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:08:12,280 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:08:12,281 DEBUG HttpMethodBase:1352 - Adding Host request header
10:08:12,282 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:08:12,289 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:08:12,290 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:08:12,292 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:08:12,293 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:08:12,294 DEBUG header:70 - >> "[\r][\n]"
10:08:12,295 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:08:12,297 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:08:12,300 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:08:12,302 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:08:12,303 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:08:12,304 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:08:12,305 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:08:12,308 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:08:12,313 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:08:12,323 DEBUG HttpMethodDirector:404 - Closing the connection.
10:08:42,358  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
10:08:42,359 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
10:08:42,363  INFO HttpMethodDirector:445 - Retrying request
10:08:42,363 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:08:42,381 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:08:42,384 DEBUG HttpMethodBase:1352 - Adding Host request header
10:08:42,386 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:08:42,387 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:08:42,387 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:08:42,388 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:08:42,389 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:08:42,389 DEBUG header:70 - >> "[\r][\n]"
10:08:42,389 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:08:42,390 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:08:42,390 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:08:42,390 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:08:42,391 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:08:42,391 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:08:42,392 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:08:42,392 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:08:42,395 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:08:42,396 DEBUG HttpMethodDirector:457 - Closing the connection.
10:09:12,431 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
10:09:12,432 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
10:09:12,432 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282192752432
10:09:12,434 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
10:09:12,439 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1295fe8named: {http://cisco.com/mse}Login
10:09:12,439 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1295fe8named: {http://cisco.com/mse}Login
10:09:12,440 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@157b46fnamed: {http://cisco.com/mse}Logout
10:09:12,440 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@157b46fnamed: {http://cisco.com/mse}Logout
10:09:12,440 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService24966838]
10:09:12,441 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpSoap12Endpoint)
10:09:12,442 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpEndpoint)
10:09:12,445 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpSoap11Endpoint)
10:09:12,445 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 9
10:09:12,445 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
10:09:12,446 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@1295fe8
10:09:12,447 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1071c84 with key: urn:uuid:A73FA32EA86E5B916D1282192752471
10:09:12,447 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
10:09:12,447 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
10:09:12,448 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1071c84 with key: urn:uuid:A73FA32EA86E5B916D1282192752471
10:09:12,448 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] action: Login
10:09:12,448 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "RMPhase"
10:09:12,449 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "RMPhase"
10:09:12,459 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "RMPhase"
10:09:12,459 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "PolicyDetermination"
10:09:12,459 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "PolicyDetermination"
10:09:12,460 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "PolicyDetermination"
10:09:12,460 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "MessageOut"
10:09:12,460 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "MessageOut"
10:09:12,460 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "MessageOut"
10:09:12,460 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "Security"
10:09:12,462 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "Security"
10:09:12,463 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "Security"
10:09:12,463 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
10:09:12,464 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:09:12,466 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,473 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,474 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
10:09:12,474 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
10:09:12,475 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
10:09:12,475 DEBUG MultiThreadedHttpConnectionManager:839 - Getting free connection, hostConfig=HostConfiguration
10:09:12,476 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:09:12,478 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:09:12,479 DEBUG HttpMethodBase:1352 - Adding Host request header
10:09:12,480 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:09:12,480 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:09:12,481 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:09:12,484 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:09:12,485 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:09:12,486 DEBUG header:70 - >> "[\r][\n]"
10:09:12,487 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:09:12,487 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:09:12,490 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:09:12,491 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:09:12,492 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:09:12,492 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:09:12,492 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,495 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:09:12,498 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
10:09:42,731 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:09:42,732 DEBUG HttpMethodDirector:404 - Closing the connection.
10:10:12,754  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
10:10:12,754 DEBUG HttpMethodDirector:443 - Read timed out
    ... 20 more
    ... 23 more
10:10:12,758  INFO HttpMethodDirector:445 - Retrying request
10:10:12,759 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:10:12,762 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:10:12,763 DEBUG HttpMethodBase:1352 - Adding Host request header
10:10:12,763 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:10:12,767 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:10:12,768 DEBUG header:70 - >> "[\r][\n]"
10:10:12,768 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:10:12,768 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:10:12,769 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:10:12,769 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:10:12,770 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:10:12,770 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:10:12,770 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:10:12,771 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:10:12,771 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:10:12,772 DEBUG HttpMethodDirector:404 - Closing the connection.
10:10:42,808  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
10:10:42,809 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
10:10:42,811  INFO HttpMethodDirector:445 - Retrying request
10:10:42,812 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:10:42,816 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:10:42,817 DEBUG HttpMethodBase:1352 - Adding Host request header
10:10:42,820 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:10:42,822 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:10:42,824 DEBUG header:70 - >> "[\r][\n]"
10:10:42,824 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:10:42,824 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:10:42,825 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:10:42,825 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:10:42,825 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:10:42,826 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:10:42,826 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:10:42,826 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:10:42,834 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:10:42,836 DEBUG HttpMethodDirector:457 - Closing the connection.
10:11:12,870 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
10:11:12,871 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
10:11:12,872 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282192872872
10:11:12,873 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
I am very new to this environment. Please Help
Amlan
Hi Amlan,
No, you do not need WCS at all.  WCS is a wireless management tool that uses the context aware api, but it is not necessary to get the simulator up and running.  You can connect directly to the MSE from your sample application.
If you are having trouble with your code, please post the snippet and your MSE ifconfig.
Matt
Subject: RE: New Message from amlan dutta in Context-Aware Mobility (Location) - Oth
Replied by: Matthew J Denapoli on 19-08-2010 03:23:36 PM
Hi Amlan,
Can you attach your code so I can review?
Matt
Matt Denapoli
Engineer.custom Application
mdenapol@cisco.com <mailto:mdenapol@cisco.com>
Phone: +1 330 523 2062
Cisco Systems, Inc.
United States
Cisco.com <http://www.cisco.com>
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
For corporate legal information go to:
http://www.cisco.com/web/about/doing_business/legal/cri/index.html <http://www.cisco.com/web/about/doing_business/legal/cri/index.html>
From: Cisco Developer Community Forums [mailto:cdicuser@developer.cisco.com]
Sent: Thursday, August 19, 2010 1:58 AM
To: cdicuser@developer.cisco.com
Subject: New Message from amlan dutta in Context-Aware Mobility (Location) - Other/Miscellaneous: RE: MSE Simulator
amlan dutta has created a new message in the forum "Other/Miscellaneous":
Thanks a lot.
My simulator is up and I can able to see the status and I can ping my MSE from my machine.
I have downloaded the Sample JAVA application available on the Cisco site. I have added all the jars and try to connect the MSE.
I am able to download the certificate but didnt able to connect the MSE, I have changed the ip address in Connecntion Constructor as MSE ip address
login name and password as admin.
but it seems getAesBusinessSession() function returing business session object as
NULL.
ifconfig of MSE is giving the result as follows
eth0   Link
encap:Ethernet  HWaddr 00:0C:29:92:70emoticon9
          inet addr:192.168.49.2  Bcast:192.168.49.255
Mask:255.255.255.0
          inet6 addr: fe80::20C:29ff:fe92:70D9/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:222 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5515 errors:52 dropped:0 overruns:0 carrier:104
          collisions:0 txqueuelen:1000
          RX bytes:23418 (22.8 Kiemoticon  TX bytes:248237 (242.4 Kiemoticon
          Interrupt:19 Base address:0x2024
lo
Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:525800 errors:0 dropped:0 overruns:0 frame:0
          TX packets:525800 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:34812887 (33.2 Miemoticon  TX bytes:34812887 (33.2Mib)
My log is as follows
18:08:20,533  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
18:09:22,952  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:09:22,959  INFO HttpMethodDirector:445 - Retrying request
18:09:45,716 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1342ba4named: {http://cisco.com/mse}Login
18:09:45,725 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1342ba4named: {http://cisco.com/mse}Login
18:09:45,726 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@8e32e7named: {http://cisco.com/mse}Logout
18:09:45,726 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@8e32e7named: {http://cisco.com/mse}Logout
18:09:45,761 DEBUG Loader:132 - Trying to find [org/apache/axis2/deployment/axis2_default.xml] using sun.misc.Launcher$AppClassLoader@601bb1 class loader.
18:09:45,795 DEBUG StAXUtils:333 - About to create XMLInputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:45,797 DEBUG StAXUtils:335 - The classloader for javax.xml.stream.XMLInputFactory is: null
18:09:45,862 DEBUG StAXUtils:382 - Created XMLInputFactory = class com.ctc.wstx.stax.WstxInputFactory with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:45,865 DEBUG StAXUtils:384 - Size of XMLInputFactory map =1
18:09:45,866 DEBUG StAXUtils:385 - isNetworkDetached =false
18:09:45,968 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
18:09:46,081 DEBUG OMNodeImpl:330 - Builder is already complete.
18:09:46,188 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Transport
18:09:46,196 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Transport
18:09:46,203 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
18:09:46,207 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
18:09:46,209 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
18:09:46,212 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
18:09:46,216 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
18:09:46,220 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
18:09:46,221 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
18:09:46,222 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
18:09:46,223 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
18:09:46,223 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
18:09:46,224 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
18:09:46,224 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
18:09:46,343 DEBUG RepositoryListener:145 - Deploying module from classpath at 'file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar'
18:09:46,521 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
18:09:46,528 DEBUG OMNodeImpl:330 - Builder is already complete.
18:09:46,572 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
18:09:46,611 DEBUG ProjectResourceBundle:412 - loadBundle: Ignoring MissingResourceException: Can't find bundle for base name org.apache.axis2.resource, locale en_IN
18:09:46,613 DEBUG ProjectResourceBundle:289 - Created org.apache.axis2.i18n.resource, linked to parent null
18:09:46,616 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
18:09:46,617 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(addingnewmodule)
18:09:46,620 DEBUG DeploymentEngine:553 - Adding new module
18:09:46,621 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(deployingmodule)
18:09:46,625  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
18:09:46,728 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService24585668]
18:09:46,860 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpEndpoint)
18:09:46,862 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpSoap11Endpoint)
18:09:46,864 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24585668,AaaService24585668HttpSoap12Endpoint)
18:09:46,866 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 3
18:09:47,365 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1bbd7b2named: {http://cisco.com/mse}Login
18:09:47,367 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1bbd7b2named: {http://cisco.com/mse}Login
18:09:47,369 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@14df764named: {http://cisco.com/mse}Logout
18:09:47,369 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@14df764named: {http://cisco.com/mse}Logout
18:09:47,370 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService21830977]
18:09:47,374 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpEndpoint)
18:09:47,374 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpSoap11Endpoint)
18:09:47,377 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService21830977,AaaService21830977HttpSoap12Endpoint)
18:09:47,380 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 6
18:09:47,382 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
18:09:47,382 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@1bbd7b2
18:09:47,500 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1035079 with key: urn:uuid:F334FD6681A32633CF1282135187515
18:09:47,505 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
18:09:47,516 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
18:09:47,522 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1035079 with key: urn:uuid:F334FD6681A32633CF1282135187515
18:09:47,523 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] action: Login
18:09:47,534 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "OperationOutPhase"
18:09:47,537 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "OperationOutPhase"
18:09:47,539 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "OperationOutPhase"
18:09:47,539 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "RMPhase"
18:09:47,539 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "RMPhase"
18:09:47,540 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "RMPhase"
18:09:47,540 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "PolicyDetermination"
18:09:47,541 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "PolicyDetermination"
18:09:47,541 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "PolicyDetermination"
18:09:47,542 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "MessageOut"
18:09:47,542 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "MessageOut"
18:09:47,545 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "MessageOut"
18:09:47,545 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking pre-condition for Phase "Security"
18:09:47,545 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Invoking phase "Security"
18:09:47,546 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135187540] Checking post-conditions for phase "Security"
18:09:47,691 DEBUG DefaultHttpParams:151 - Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
18:09:47,699 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.version = HTTP/1.1
18:09:47,708 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
18:09:47,710 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.cookie-policy = default
18:09:47,712 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.element-charset = US-ASCII
18:09:47,713 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.content-charset = ISO-8859-1
18:09:47,718 DEBUG DefaultHttpParams:151 - Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@160877b
18:09:47,723 DEBUG DefaultHttpParams:151 - Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
18:09:47,757 DEBUG HttpClient:72 - Java version: 1.6.0_20
18:09:47,760 DEBUG HttpClient:73 - Java vendor: Sun Microsystems Inc.
18:09:47,763 DEBUG HttpClient:74 - Java class path: /home/amlan/Downloads/MSE/java/bin:/home/amlan/Downloads/MSE/java/jars/aaaService-test-client-5.2.jar:/home/amlan/Downloads/MSE/java/jars/LocationService-test-client-5.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/activation-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-api-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-dom-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-impl-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-ant-plugin-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-clustering-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-corba-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-fastinfoset-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-java2wsdl-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxbri-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxws-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jibx-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-json-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-kernel-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-metadata-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-mtompolicy-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-saaj-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-spring-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-http-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-local-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-xmlbeans-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/bcel-5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-codec-1.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-fileupload-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-httpclient-3.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-io-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-lang-2.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-logging-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-annotation_1.0_spec-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-jaxws_2.1_spec-1.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-saaj_1.3_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-stax-api_1.0_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-ws-metadata_2.0_spec-1.1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/httpcore-4.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jalopy-1.5rc3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-api-2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-impl-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-xjc-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxen-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jettison-1.0-RC2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-bind-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-run-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/log4j-1.2.15.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mail-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/neethi-2.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smack-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smackx-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/soapmonitor-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-api-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-impl-dom-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wsdl4j-1.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wstx-asl-3.2.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xalan-2.7.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xercesImpl-2.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-apis-1.3.02.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xmlbeans-2.3.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-resolver-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/XmlSchema-1.4.3.jar
18:09:47,765 DEBUG HttpClient:75 - Operating system name: Linux
18:09:47,766 DEBUG HttpClient:76 - Operating system architecture: i386
18:09:47,767 DEBUG HttpClient:77 - Operating system version: 2.6.32-21-generic
18:09:48,008 DEBUG HttpClient:82 - SUN 1.6: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
18:09:48,010 DEBUG HttpClient:82 - SunRsaSign 1.5: Sun RSA signature provider
18:09:48,011 DEBUG HttpClient:82 - SunJSSE 1.6: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
18:09:48,012 DEBUG HttpClient:82 - SunJCE 1.6: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
18:09:48,013 DEBUG HttpClient:82 - SunJGSS 1.0: Sun (Kerberos v5, SPNEGO)
18:09:48,014 DEBUG HttpClient:82 - SunSASL 1.5: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
18:09:48,015 DEBUG HttpClient:82 - XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
18:09:48,017 DEBUG HttpClient:82 - SunPCSC 1.6: Sun PC/SC provider
18:09:48,046 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.timeout = 30000
18:09:48,052 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
18:09:48,053 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:09:48,054 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:09:48,101 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,103 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,104 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
18:09:48,104 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
18:09:48,195 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
18:09:48,204 DEBUG MultiThreadedHttpConnectionManager:760 - Allocating new connection, hostConfig=HostConfiguration
18:09:48,228 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:09:48,889 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:09:48,896 DEBUG HttpMethodBase:1352 - Adding Host request header
18:09:48,917 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:09:48,919 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:09:48,919 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:09:48,920 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:09:48,920 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:09:48,921 DEBUG header:70 - >> "[\r][\n]"
18:09:48,922 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:09:48,922 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:09:48,923 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:09:48,923 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:09:48,924 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:09:48,929 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:09:48,932 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:09:48,933 DEBUG StAXUtils:452 - About to create XMLOutputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:48,933 DEBUG StAXUtils:454 - The classloader for javax.xml.stream.XMLOutputFactory is: null
18:09:48,984 DEBUG StAXUtils:500 - Created XMLOutputFactory = class com.ctc.wstx.stax.WstxOutputFactory for classloader=sun.misc.Launcher$AppClassLoader@601bb1
18:09:48,986 DEBUG StAXUtils:502 - Size of XMLOutputFactory map =1
18:09:49,003 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:09:49,024 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
18:10:19,143 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:10:19,145 DEBUG HttpMethodDirector:404 - Closing the connection.
18:10:49,175  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:10:49,180 DEBUG HttpMethodDirector:443 - Read timed out
org.apache.axis2.AxisFault: Read timed out
    at org.apache.axis2.AxisFault.makeFault(AxisFault.java:430)
    at org.apache.axis2.transport.http.SOAPMessageFormatter.writeTo(SOAPMessageFormatter.java:83)
    at org.apache.axis2.transport.http.AxisRequestEntity.writeRequest(AxisRequestEntity.java:84)
    at org.apache.commons.httpclient.methods.EntityEnclosingMethod.writeRequestBody(EntityEnclosingMethod.java:499)
    at org.apache.commons.httpclient.HttpMethodBase.writeRequest(HttpMethodBase.java:2114)
    at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMethodBase.java:1096)
    at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:398)
    at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
    at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
    at org.apache.axis2.transport.http.AbstractHTTPSender.executeMethod(AbstractHTTPSender.java:542)
    at org.apache.axis2.transport.http.HTTPSender.sendViaPost(HTTPSender.java:199)
    at org.apache.axis2.transport.http.HTTPSender.send(HTTPSender.java:76)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.writeMessageWithCommons(CommonsHTTPTransportSender.java:400)
    at org.apache.axis2.transport.http.CommonsHTTPTransportSender.invoke(CommonsHTTPTransportSender.java:225)
    at org.apache.axis2.engine.AxisEngine.send(AxisEngine.java:435)
    at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:402)
    at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229)
    at org.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
    at com.cisco.mse.AaaServiceStub.Login(AaaServiceStub.java:148)
    at com.cisco.mse.aaa.Connection.Login(Connection.java:86)
    at com.cisco.mse.aaa.Connection.main(Connection.java:53)
Caused by: com.ctc.wstx.exc.WstxIOException: Read timed out
    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:313)
    at org.apache.axiom.om.impl.MTOMXMLStreamWriter.flush(MTOMXMLStreamWriter.java:168)
    at org.apache.axiom.om.impl.llom.OMNodeImpl.serializeAndConsume(OMNodeImpl.java:487)
    at org.apache.axis2.transport.http.SOAPMessageFormatter.writeTo(SOAPMessageFormatter.java:79)
    ... 20 more
Caused by: java.net.SocketTimeoutException: Read timed out
    at java.net.SocketInputStream.socketRead0(Native Method)
    at java.net.SocketInputStream.read(SocketInputStream.java:129)
    at com.sun.net.ssl.internal.ssl.InputRecord.readFully(InputRecord.java:293)
    at com.sun.net.ssl.internal.ssl.InputRecord.read(InputRecord.java:331)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:789)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1120)
    at com.sun.net.ssl.internal.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:623)
    at com.sun.net.ssl.internal.ssl.AppOutputStream.write(AppOutputStream.java:59)
    at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
    at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
    at java.io.FilterOutputStream.flush(FilterOutputStream.java:123)
    at org.apache.commons.httpclient.ChunkedOutputStream.flush(ChunkedOutputStream.java:191)
    at com.ctc.wstx.io.UTF8Writer.flush(UTF8Writer.java:99)
    at com.ctc.wstx.sw.BufferingXmlWriter.flush(BufferingXmlWriter.java:214)
    at com.ctc.wstx.sw.BaseStreamWriter.flush(BaseStreamWriter.java:311)
    ... 23 more
18:10:49,197  INFO HttpMethodDirector:445 - Retrying request
18:10:49,197 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:10:49,200 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:10:49,201 DEBUG HttpMethodBase:1352 - Adding Host request header
18:10:49,201 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:10:49,202 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:10:49,203 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:10:49,204 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:10:49,204 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:10:49,205 DEBUG header:70 - >> "[\r][\n]"
18:10:49,209 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:10:49,209 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:10:49,210 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:10:49,210 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:10:49,211 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:10:49,212 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:10:49,212 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:10:49,214 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:10:49,216 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:10:49,222 DEBUG HttpMethodDirector:404 - Closing the connection.
18:11:19,461  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
18:11:19,461 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
org.apache.axis2.AxisFault: problem accessing the parser. Parser already accessed!
Caused by: javax.xml.stream.XMLStreamException: problem accessing the parser. Parser already accessed!
    at org.apache.axiom.om.impl.llom.OMStAXWrapper.next(OMStAXWrapper.java:983)
    at org.apache.axiom.om.util.OMXMLStreamReaderValidator.next(OMXMLStreamReaderValidator.java:76)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serializeNode(StreamingOMSerializer.java:125)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serialize(StreamingOMSerializer.java:93)
    at org.apache.axiom.om.impl.serialize.StreamingOMSerializer.serialize(StreamingOMSerializer.java:76)
    at org.apache.axiom.om.impl.util.OMSerializerUtil.serializeByPullStream(OMSerializerUtil.java:579)
    at org.apache.axiom.om.impl.llom.OMElementImpl.internalSerialize(OMElementImpl.java:970)
    at org.apache.axiom.om.impl.llom.OMElementImpl.internalSerializeAndConsume(OMElementImpl.java:995)
    at org.apache.axiom.soap.impl.llom.SOAPEnvelopeImpl.serializeInternally(SOAPEnvelopeImpl.java:254)
    at org.apache.axiom.soap.impl.llom.SOAPEnvelopeImpl.internalSerialize(SOAPEnvelopeImpl.java:242)
    at org.apache.axiom.om.impl.llom.OMNodeImpl.serializeAndConsume(OMNodeImpl.java:486)
    ... 20 more
Caused by: java.lang.IllegalStateException: Parser already accessed!
    at org.apache.axiom.om.impl.builder.StAXBuilder.getParser(StAXBuilder.java:508)
    at org.apache.axiom.om.impl.llom.OMStAXWrapper.next(OMStAXWrapper.java:981)
    ... 32 more
18:11:19,465  INFO HttpMethodDirector:445 - Retrying request
18:11:19,466 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:11:19,476 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:11:19,478 DEBUG HttpMethodBase:1352 - Adding Host request header
18:11:19,479 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:11:19,480 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:11:19,481 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:11:19,482 DEBUG header:70 - >> "[\r][\n]"
18:11:19,482 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:11:19,482 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:11:19,483 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:11:19,483 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:11:19,483 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:11:19,484 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:11:19,484 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:19,485 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:11:19,486 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:11:19,486 DEBUG HttpMethodDirector:457 - Closing the connection.
18:11:49,524 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
18:11:49,524 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
18:11:49,525 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282135309525
18:11:49,525 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
18:11:49,542 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@633d51named: {http://cisco.com/mse}Login
18:11:49,543 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@633d51named: {http://cisco.com/mse}Login
18:11:49,544 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@14eaec9named: {http://cisco.com/mse}Logout
18:11:49,544 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@14eaec9named: {http://cisco.com/mse}Logout
18:11:49,545 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService9715140]
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpSoap11Endpoint)
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpSoap12Endpoint)
18:11:49,546 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService9715140,AaaService9715140HttpEndpoint)
18:11:49,547 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 9
18:11:49,547 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
18:11:49,547 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@633d51
18:11:49,548 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@b533b8 with key: urn:uuid:F334FD6681A32633CF1282135309572
18:11:49,548 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
18:11:49,548 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
18:11:49,549 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@b533b8 with key: urn:uuid:F334FD6681A32633CF1282135309572
18:11:49,549 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] action: Login
18:11:49,549 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "OperationOutPhase"
18:11:49,550 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "RMPhase"
18:11:49,550 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "RMPhase"
18:11:49,551 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "RMPhase"
18:11:49,559 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "PolicyDetermination"
18:11:49,560 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "PolicyDetermination"
18:11:49,560 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "PolicyDetermination"
18:11:49,561 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "MessageOut"
18:11:49,561 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "MessageOut"
18:11:49,561 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "MessageOut"
18:11:49,562 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking pre-condition for Phase "Security"
18:11:49,562 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Invoking phase "Security"
18:11:49,563 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:F334FD6681A32633CF1282135309574] Checking post-conditions for phase "Security"
18:11:49,564 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
18:11:49,565 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
18:11:49,566 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,566 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,567 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
18:11:49,567 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
18:11:49,571 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
18:11:49,572 DEBUG MultiThreadedHttpConnectionManager:839 - Getting free connection, hostConfig=HostConfiguration
18:11:49,573 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:11:49,575 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:11:49,576 DEBUG HttpMethodBase:1352 - Adding Host request header
18:11:49,577 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:11:49,578 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:11:49,578 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:11:49,579 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:11:49,583 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:11:49,583 DEBUG header:70 - >> "[\r][\n]"
18:11:49,584 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:11:49,585 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:11:49,585 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:11:49,586 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:11:49,586 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:11:49,586 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:11:49,587 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:11:49,587 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:11:49,588 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
18:12:19,624 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:12:19,625 DEBUG HttpMethodDirector:404 - Closing the connection.
18:12:49,655  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
18:12:49,656 DEBUG HttpMethodDirector:443 - Read timed out
    at com.cisco.mse.aaa.Connection.main(Connection.java:54)
    ... 20 more
    ... 23 more
18:12:49,657  INFO HttpMethodDirector:445 - Retrying request
18:12:49,657 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:12:49,678 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:12:49,678 DEBUG HttpMethodBase:1352 - Adding Host request header
18:12:49,679 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:12:49,680 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:12:49,681 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:12:49,685 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:12:49,686 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:12:49,687 DEBUG header:70 - >> "[\r][\n]"
18:12:49,688 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:12:49,692 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:12:49,694 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:12:49,694 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:12:49,696 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:12:49,697 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:12:49,698 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:12:49,699 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:12:49,700 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:12:49,702 DEBUG HttpMethodDirector:404 - Closing the connection.
18:13:19,741  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
18:13:19,754 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
18:13:19,780  INFO HttpMethodDirector:445 - Retrying request
18:13:19,780 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
18:13:19,783 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
18:13:19,784 DEBUG HttpMethodBase:1352 - Adding Host request header
18:13:19,785 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
18:13:19,786 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
18:13:19,787 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
18:13:19,788 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
18:13:19,789 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
18:13:19,789 DEBUG header:70 - >> "[\r][\n]"
18:13:19,790 DEBUG SOAPMessageFormatter:51 - start writeTo()
18:13:19,792 DEBUG SOAPMessageFormatter:52 -   preserve=false
18:13:19,794 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
18:13:19,795 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
18:13:19,796 DEBUG Utils:479 - MTOM optimized Threshold value =0
18:13:19,796 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
18:13:19,796 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
18:13:19,797 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
18:13:19,806 DEBUG SOAPMessageFormatter:86 - end writeTo()
18:13:19,806 DEBUG HttpMethodDirector:457 - Closing the connection.
18:13:50,068 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
18:13:50,069 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
18:13:50,069 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282135430069
18:13:50,069 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
10:07:07,422 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1d332bnamed: {http://cisco.com/mse}Login
10:07:07,477 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1d332bnamed: {http://cisco.com/mse}Login
10:07:07,478 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@1b000e7named: {http://cisco.com/mse}Logout
10:07:07,479 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@1b000e7named: {http://cisco.com/mse}Logout
10:07:07,579 DEBUG Loader:132 - Trying to find [org/apache/axis2/deployment/axis2_default.xml] using sun.misc.Launcher$AppClassLoader@601bb1 class loader.
10:07:07,630 DEBUG StAXUtils:333 - About to create XMLInputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:07,633 DEBUG StAXUtils:335 - The classloader for javax.xml.stream.XMLInputFactory is: null
10:07:07,736 DEBUG StAXUtils:382 - Created XMLInputFactory = class com.ctc.wstx.stax.WstxInputFactory with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:07,738 DEBUG StAXUtils:384 - Size of XMLInputFactory map =1
10:07:07,739 DEBUG StAXUtils:385 - isNetworkDetached =false
10:07:07,877 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
10:07:08,010 DEBUG OMNodeImpl:330 - Builder is already complete.
10:07:08,203 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Transport
10:07:08,213 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Transport
10:07:08,257 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
10:07:08,261 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
10:07:08,264 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
10:07:08,269 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
10:07:08,273 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
10:07:08,277 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
10:07:08,278 DEBUG Phase:98 - Handler AddressingBasedDispatcher added to Phase Addressing
10:07:08,279 DEBUG Phase:98 - Handler RequestURIBasedDispatcher added to Phase Dispatch
10:07:08,282 DEBUG Phase:98 - Handler SOAPActionBasedDispatcher added to Phase Dispatch
10:07:08,283 DEBUG Phase:98 - Handler RequestURIOperationDispatcher added to Phase Dispatch
10:07:08,284 DEBUG Phase:98 - Handler SOAPMessageBodyBasedDispatcher added to Phase Dispatch
10:07:08,285 DEBUG Phase:98 - Handler HTTPLocationBasedDispatcher added to Phase Dispatch
10:07:08,372 DEBUG RepositoryListener:145 - Deploying module from classpath at 'file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar'
10:07:08,544 DEBUG StAXUtils:146 - XMLStreamReader is com.ctc.wstx.sr.ValidatingStreamReader
10:07:08,548 DEBUG OMNodeImpl:330 - Builder is already complete.
10:07:08,573 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
10:07:08,599 DEBUG ProjectResourceBundle:412 - loadBundle: Ignoring MissingResourceException: Can't find bundle for base name org.apache.axis2.resource, locale en_IN
10:07:08,601 DEBUG ProjectResourceBundle:289 - Created org.apache.axis2.i18n.resource, linked to parent null
10:07:08,603 DEBUG ProjectResourceBundle:236 - getBundle(org.apache.axis2,org.apache.axis2.i18n,resource,null,...)
10:07:08,605 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(addingnewmodule)
10:07:08,607 DEBUG DeploymentEngine:553 - Adding new module
10:07:08,608 DEBUG ProjectResourceBundle:70 - org.apache.axis2.i18n.resource::handleGetObject(deployingmodule)
10:07:08,609  INFO ModuleDeployer:75 - Deploying module: metadataExchange-1.5.1 - file:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar
10:07:08,713 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService22048196]
10:07:08,890 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpEndpoint)
10:07:08,896 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpSoap11Endpoint)
10:07:08,897 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22048196,AaaService22048196HttpSoap12Endpoint)
10:07:08,898 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 3
10:07:09,775 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@55bb93named: {http://cisco.com/mse}Login
10:07:09,777 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@55bb93named: {http://cisco.com/mse}Login
10:07:09,778 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@8de462named: {http://cisco.com/mse}Logout
10:07:09,778 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@8de462named: {http://cisco.com/mse}Logout
10:07:09,780 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService22927632]
10:07:09,783 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpSoap12Endpoint)
10:07:09,784 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpSoap11Endpoint)
10:07:09,784 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService22927632,AaaService22927632HttpEndpoint)
10:07:09,789 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 6
10:07:09,791 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
10:07:09,791 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@55bb93
10:07:09,954 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@983d95 with key: urn:uuid:A73FA32EA86E5B916D1282192629970
10:07:09,956 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
10:07:09,963 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
10:07:09,970 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@983d95 with key: urn:uuid:A73FA32EA86E5B916D1282192629970
10:07:09,972 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] action: Login
10:07:09,982 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "OperationOutPhase"
10:07:09,983 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "OperationOutPhase"
10:07:09,984 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "OperationOutPhase"
10:07:09,984 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "RMPhase"
10:07:09,985 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "RMPhase"
10:07:09,985 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "RMPhase"
10:07:09,985 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "PolicyDetermination"
10:07:09,985 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "PolicyDetermination"
10:07:09,986 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "PolicyDetermination"
10:07:09,986 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "MessageOut"
10:07:09,986 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "MessageOut"
10:07:09,988 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "MessageOut"
10:07:09,989 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking pre-condition for Phase "Security"
10:07:09,989 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Invoking phase "Security"
10:07:09,989 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192629989] Checking post-conditions for phase "Security"
10:07:10,078 DEBUG DefaultHttpParams:151 - Set parameter http.useragent = Jakarta Commons-HttpClient/3.1
10:07:10,082 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.version = HTTP/1.1
10:07:10,085 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.class = class org.apache.commons.httpclient.SimpleHttpConnectionManager
10:07:10,086 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.cookie-policy = default
10:07:10,086 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.element-charset = US-ASCII
10:07:10,087 DEBUG DefaultHttpParams:151 - Set parameter http.protocol.content-charset = ISO-8859-1
10:07:10,092 DEBUG DefaultHttpParams:151 - Set parameter http.method.retry-handler = org.apache.commons.httpclient.DefaultHttpMethodRetryHandler@5eb489
10:07:10,094 DEBUG DefaultHttpParams:151 - Set parameter http.dateparser.patterns = [EEE, dd MMM yyyy HH:mm:ss zzz, EEEE, dd-MMM-yy HH:mm:ss zzz, EEE MMM d HH:mm:ss yyyy, EEE, dd-MMM-yyyy HH:mm:ss z, EEE, dd-MMM-yyyy HH-mm-ss z, EEE, dd MMM yy HH:mm:ss z, EEE dd-MMM-yyyy HH:mm:ss z, EEE dd MMM yyyy HH:mm:ss z, EEE dd-MMM-yyyy HH-mm-ss z, EEE dd-MMM-yy HH:mm:ss z, EEE dd MMM yy HH:mm:ss z, EEE,dd-MMM-yy HH:mm:ss z, EEE,dd-MMM-yyyy HH:mm:ss z, EEE, dd-MM-yyyy HH:mm:ss z]
10:07:10,105 DEBUG HttpClient:72 - Java version: 1.6.0_20
10:07:10,107 DEBUG HttpClient:73 - Java vendor: Sun Microsystems Inc.
10:07:10,108 DEBUG HttpClient:74 - Java class path: /home/amlan/Downloads/MSE/java/bin:/home/amlan/Downloads/MSE/java/jars/aaaService-test-client-5.2.jar:/home/amlan/Downloads/MSE/java/jars/LocationService-test-client-5.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/activation-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-api-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-dom-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axiom-impl-1.2.8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-adb-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-ant-plugin-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-clustering-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-codegen-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-corba-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-fastinfoset-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-java2wsdl-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxbri-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jaxws-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-jibx-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-json-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-kernel-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-metadata-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-mtompolicy-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-saaj-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-spring-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-http-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-transport-local-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/axis2-xmlbeans-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/bcel-5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-codec-1.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-fileupload-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-httpclient-3.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-io-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-lang-2.3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/commons-logging-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-annotation_1.0_spec-1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-jaxws_2.1_spec-1.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-saaj_1.3_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-stax-api_1.0_spec-1.0.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/geronimo-ws-metadata_2.0_spec-1.1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/httpcore-4.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jalopy-1.5rc3.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-api-2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-impl-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxb-xjc-2.1.7.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jaxen-1.1.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jettison-1.0-RC2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-bind-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/jibx-run-1.2.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/log4j-1.2.15.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mail-1.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/mex-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/neethi-2.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smack-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/smackx-3.0.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/soapmonitor-1.5.1.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-api-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/woden-impl-dom-1.0M8.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wsdl4j-1.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/wstx-asl-3.2.4.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xalan-2.7.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xercesImpl-2.6.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-apis-1.3.02.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xmlbeans-2.3.0.jar:/home/amlan/Downloads/axis2-1.5.1/lib/xml-resolver-1.2.jar:/home/amlan/Downloads/axis2-1.5.1/lib/XmlSchema-1.4.3.jar
10:07:10,108 DEBUG HttpClient:75 - Operating system name: Linux
10:07:10,109 DEBUG HttpClient:76 - Operating system architecture: i386
10:07:10,109 DEBUG HttpClient:77 - Operating system version: 2.6.32-21-generic
10:07:10,437 DEBUG HttpClient:82 - SUN 1.6: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; JKS keystore; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
10:07:10,439 DEBUG HttpClient:82 - SunRsaSign 1.5: Sun RSA signature provider
10:07:10,439 DEBUG HttpClient:82 - SunJSSE 1.6: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
10:07:10,439 DEBUG HttpClient:82 - SunJCE 1.6: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC)
10:07:10,440 DEBUG HttpClient:82 - SunJGSS 1.0: Sun (Kerberos v5, SPNEGO)
10:07:10,440 DEBUG HttpClient:82 - SunSASL 1.5: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, GSSAPI, EXTERNAL, PLAIN, CRAM-MD5; server mechanisms for: DIGEST-MD5, GSSAPI, CRAM-MD5)
10:07:10,441 DEBUG HttpClient:82 - XMLDSig 1.0: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory)
10:07:10,441 DEBUG HttpClient:82 - SunPCSC 1.6: Sun PC/SC provider
10:07:10,459 DEBUG DefaultHttpParams:151 - Set parameter http.connection-manager.timeout = 30000
10:07:10,463 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
10:07:10,464 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:07:10,465 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:07:10,485 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:10,487 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:10,488 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
10:07:10,488 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
10:07:10,530 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
10:07:10,534 DEBUG MultiThreadedHttpConnectionManager:760 - Allocating new connection, hostConfig=HostConfiguration
10:07:10,546 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:07:11,589 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:07:11,595 DEBUG HttpMethodBase:1352 - Adding Host request header
10:07:11,624 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:07:11,625 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:07:11,626 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:07:11,627 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:07:11,627 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:07:11,628 DEBUG header:70 - >> "[\r][\n]"
10:07:11,629 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:07:11,630 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:07:11,630 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:07:11,630 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:07:11,631 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:07:11,637 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:07:11,639 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:07:11,640 DEBUG StAXUtils:452 - About to create XMLOutputFactory implementation with classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:11,641 DEBUG StAXUtils:454 - The classloader for javax.xml.stream.XMLOutputFactory is: null
10:07:11,681 DEBUG StAXUtils:500 - Created XMLOutputFactory = class com.ctc.wstx.stax.WstxOutputFactory for classloader=sun.misc.Launcher$AppClassLoader@601bb1
10:07:11,683 DEBUG StAXUtils:502 - Size of XMLOutputFactory map =1
10:07:11,707 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:07:11,732 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
10:07:42,234 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:07:42,236 DEBUG HttpMethodDirector:404 - Closing the connection.
10:08:12,264  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
10:08:12,268 DEBUG HttpMethodDirector:443 - Read timed out
    ... 20 more
    ... 23 more
10:08:12,274  INFO HttpMethodDirector:445 - Retrying request
10:08:12,277 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:08:12,280 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:08:12,281 DEBUG HttpMethodBase:1352 - Adding Host request header
10:08:12,282 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:08:12,289 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:08:12,290 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:08:12,292 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:08:12,293 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:08:12,294 DEBUG header:70 - >> "[\r][\n]"
10:08:12,295 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:08:12,297 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:08:12,300 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:08:12,302 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:08:12,303 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:08:12,304 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:08:12,305 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:08:12,308 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:08:12,313 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:08:12,323 DEBUG HttpMethodDirector:404 - Closing the connection.
10:08:42,358  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
10:08:42,359 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
10:08:42,363  INFO HttpMethodDirector:445 - Retrying request
10:08:42,363 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:08:42,381 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:08:42,384 DEBUG HttpMethodBase:1352 - Adding Host request header
10:08:42,386 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:08:42,387 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:08:42,387 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:08:42,388 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:08:42,389 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:08:42,389 DEBUG header:70 - >> "[\r][\n]"
10:08:42,389 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:08:42,390 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:08:42,390 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:08:42,390 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:08:42,391 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:08:42,391 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:08:42,392 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:08:42,392 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:08:42,395 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:08:42,396 DEBUG HttpMethodDirector:457 - Closing the connection.
10:09:12,431 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
10:09:12,432 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
10:09:12,432 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282192752432
10:09:12,434 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
10:09:12,439 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Login; operation: org.apache.axis2.description.OutInAxisOperation@1295fe8named: {http://cisco.com/mse}Login
10:09:12,439 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Login; operation: org.apache.axis2.description.OutInAxisOperation@1295fe8named: {http://cisco.com/mse}Login
10:09:12,440 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: Logout; operation: org.apache.axis2.description.OutInAxisOperation@157b46fnamed: {http://cisco.com/mse}Logout
10:09:12,440 DEBUG AxisService:788 - mapActionToOperation: Mapping Action to Operation: action: urn:Logout; operation: org.apache.axis2.description.OutInAxisOperation@157b46fnamed: {http://cisco.com/mse}Logout
10:09:12,440 DEBUG AxisConfiguration:397 - Adding service to allServices map: [AaaService24966838]
10:09:12,441 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpSoap12Endpoint)
10:09:12,442 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpEndpoint)
10:09:12,445 DEBUG AxisConfiguration:371 - Adding service to allEndpoints map: (AaaService24966838,AaaService24966838HttpSoap11Endpoint)
10:09:12,445 DEBUG AxisConfiguration:378 - After adding to allEndpoints map, size is 9
10:09:12,445 DEBUG AxisService:1688 - Get operation for {http://cisco.com/mse}Login
10:09:12,446 DEBUG AxisService:1731 - Found axis operation:  org.apache.axis2.description.OutInAxisOperation@1295fe8
10:09:12,447 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1071c84 with key: urn:uuid:A73FA32EA86E5B916D1282192752471
10:09:12,447 DEBUG OutInAxisOperationClient:168 - Entry: OutInAxisOperationClient::execute, true
10:09:12,447 DEBUG OutInAxisOperationClient:198 - OutInAxisOperationClient: useAsyncOption null
10:09:12,448 DEBUG ConfigurationContext:332 - registerOperationContext (false): org.apache.axis2.context.OperationContext@1071c84 with key: urn:uuid:A73FA32EA86E5B916D1282192752471
10:09:12,448 DEBUG ConfigurationContext:338 - msgContext: [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] action: Login
10:09:12,448 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "OperationOutPhase"
10:09:12,449 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "RMPhase"
10:09:12,449 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "RMPhase"
10:09:12,459 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "RMPhase"
10:09:12,459 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "PolicyDetermination"
10:09:12,459 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "PolicyDetermination"
10:09:12,460 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "PolicyDetermination"
10:09:12,460 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "MessageOut"
10:09:12,460 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "MessageOut"
10:09:12,460 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "MessageOut"
10:09:12,460 DEBUG Phase:293 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking pre-condition for Phase "Security"
10:09:12,462 DEBUG Phase:306 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Invoking phase "Security"
10:09:12,463 DEBUG Phase:329 - [MessageContext: logID=urn:uuid:A73FA32EA86E5B916D1282192752473] Checking post-conditions for phase "Security"
10:09:12,463 DEBUG DefaultHttpParams:151 - Set parameter http.connection.timeout = 30000
10:09:12,464 DEBUG DefaultHttpParams:151 - Set parameter http.socket.timeout = 30000
10:09:12,466 DEBUG OMOutputFormat:128 - Start getContentType: OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=null ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,473 DEBUG OMOutputFormat:154 - getContentType= {text/xml}   OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,474 DEBUG SOAPMessageFormatter:133 - contentType from the OMOutputFormat =text/xml
10:09:12,474 DEBUG SOAPMessageFormatter:158 - contentType returned =text/xml; charset=UTF-8
10:09:12,475 DEBUG MultiThreadedHttpConnectionManager:412 - HttpConnectionManager.getConnection:  config = HostConfiguration, timeout = 30000
10:09:12,475 DEBUG MultiThreadedHttpConnectionManager:839 - Getting free connection, hostConfig=HostConfiguration
10:09:12,476 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:09:12,478 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:09:12,479 DEBUG HttpMethodBase:1352 - Adding Host request header
10:09:12,480 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:09:12,480 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:09:12,481 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:09:12,484 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:09:12,485 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:09:12,486 DEBUG header:70 - >> "[\r][\n]"
10:09:12,487 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:09:12,487 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:09:12,490 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:09:12,491 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:09:12,492 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:09:12,492 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:09:12,492 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:09:12,495 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:09:12,498 DEBUG MTOMXMLStreamWriter:166 - Calling MTOMXMLStreamWriter.flush
10:09:42,731 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:09:42,732 DEBUG HttpMethodDirector:404 - Closing the connection.
10:10:12,754  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: Read timed out
10:10:12,754 DEBUG HttpMethodDirector:443 - Read timed out
    ... 20 more
    ... 23 more
10:10:12,758  INFO HttpMethodDirector:445 - Retrying request
10:10:12,759 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:10:12,762 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:10:12,763 DEBUG HttpMethodBase:1352 - Adding Host request header
10:10:12,763 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:10:12,764 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:10:12,767 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:10:12,768 DEBUG header:70 - >> "[\r][\n]"
10:10:12,768 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:10:12,768 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:10:12,769 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:10:12,769 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:10:12,770 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:10:12,770 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:10:12,770 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:10:12,771 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:10:12,771 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:10:12,772 DEBUG HttpMethodDirector:404 - Closing the connection.
10:10:42,808  INFO HttpMethodDirector:439 - I/O exception (org.apache.axis2.AxisFault) caught when processing request: problem accessing the parser. Parser already accessed!
10:10:42,809 DEBUG HttpMethodDirector:443 - problem accessing the parser. Parser already accessed!
    ... 20 more
    ... 32 more
10:10:42,811  INFO HttpMethodDirector:445 - Retrying request
10:10:42,812 DEBUG HttpConnection:692 - Open connection to 192.168.49.2:8001
10:10:42,816 DEBUG header:70 - >> "POST /aaa/ HTTP/1.1[\r][\n]"
10:10:42,817 DEBUG HttpMethodBase:1352 - Adding Host request header
10:10:42,820 DEBUG header:70 - >> "Content-Type: text/xml; charset=UTF-8[\r][\n]"
10:10:42,822 DEBUG header:70 - >> "SOAPAction: "Login"[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "User-Agent: Axis2[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "Transfer-Encoding: chunked[\r][\n]"
10:10:42,823 DEBUG header:70 - >> "Host: 192.168.49.2:8001[\r][\n]"
10:10:42,824 DEBUG header:70 - >> "[\r][\n]"
10:10:42,824 DEBUG SOAPMessageFormatter:51 - start writeTo()
10:10:42,824 DEBUG SOAPMessageFormatter:52 -   preserve=false
10:10:42,825 DEBUG SOAPMessageFormatter:53 -   isOptimized=false
10:10:42,825 DEBUG SOAPMessageFormatter:54 -   isDoingSWA=false
10:10:42,825 DEBUG Utils:479 - MTOM optimized Threshold value =0
10:10:42,826 DEBUG MTOMXMLStreamWriter:90 - OutputStream =class org.apache.commons.httpclient.ChunkedOutputStream
10:10:42,826 DEBUG MTOMXMLStreamWriter:91 - OMFormat = OMOutputFormat [ mimeBoundary =null rootContentId=null doOptimize=false doingSWA=false isSOAP11=true charSetEncoding=UTF-8 xmlVersion=null contentType=text/xml ignoreXmlDeclaration=false autoCloseWriter=false actionProperty=null optimizedThreshold=0]
10:10:42,826 DEBUG StAXUtils:257 - XMLStreamWriter is com.ctc.wstx.sw.SimpleNsStreamWriter
10:10:42,834 DEBUG SOAPMessageFormatter:86 - end writeTo()
10:10:42,836 DEBUG HttpMethodDirector:457 - Closing the connection.
10:11:12,870 DEBUG HttpConnection:1178 - Releasing connection back to connection manager.
10:11:12,871 DEBUG MultiThreadedHttpConnectionManager:979 - Freeing connection, hostConfig=HostConfiguration
10:11:12,872 DEBUG IdleConnectionHandler:76 - Adding connection at: 1282192872872
10:11:12,873 DEBUG MultiThreadedHttpConnectionManager:961 - Notifying no-one, there are no waiting threads
I am very new to this environment. Please Help
Amlan
Hi Amlan,
No, you do not need WCS at all.  WCS is a wireless management tool that uses the context aware api, but it is not necessary to get the simulator up and running.  You can connect directly to the MSE from your sample application.
If you are having trouble with your code, please post the snippet and your MSE ifconfig.
Matt
To respond to this post, please click the following link:
<http://developer.cisco.com/web/contextaware/forums/-/message_boards/message/2451371>
or simply reply to this email.
Subject: RE: New Message from amlan dutta in Context-Aware Mobility (Location) - Oth
Replied by: Matthew J Denapoli on 20-08-2010 04:31:33 PM
Hi Amlan,
Your code looks ok, but I took a closer look at the logs you posted and it looks like you are getting a socket connection timeout.  Are you on a VPN connection (or something similar) when trying this?  If so, disconnect and give it a shot.  Also, make sure that all of the axis2 .jars are in your Java build path.
Matt
Replied by: amlan dutta on 20-08-2010 05:51:01 AM
Thanks a lot for your reply.
This is the sample java code for context aware services. Here follows
package com.cisco.mse.aaa;
import com.cisco.mse.*;
import com.cisco.mse.location.LocationServiceStub;
import com.cisco.mse.types.AesBusinessSession;
import com.cisco.mse.types.AesLogin;
import com.cisco.mse.types.LoginDocument;
import com.cisco.mse.types.LoginMethodArgs;
import com.cisco.mse.types.LogoutDocument;
import com.cisco.mse.types.LogoutMethodArgs;
import com.cisco.mse.types.ResponseDocument;
import com.cisco.mse.types.SessionDocument;
import java.rmi.RemoteException;
import java.security.Security;
import javax.net.ssl.HostnameVerifier;
import javax.net.ssl.HttpsURLConnection;
import javax.net.ssl.SSLSession;
import org.apache.axis2.AxisFault;
import org.apache.axis2.client.Options;
import org.apache.axis2.client.ServiceClient;
import org.apache.axis2.transport.http.HTTPConstants;
import org.apache.log4j.xml.DOMConfigurator;
public class Connection {
    private AaaServiceStub connectionStub = null;
    private LocationServiceStub stub = null;
    private AesBusinessSession AB=null;
    private String locserverurl="https://192.168.49.2/"; //mse ip address
    private String locserveruserName ="admin";
    private String locserverPassword ="admin";
    public Connection()
        //DOMConfigurator.configure("Log4j.xml");
     System.setProperty("javax.net.ssl.trustStore",
         "/home/amlan/Downloads/MSE/java/jssecacerts");
    // Security.addProvider( new com.sun.net.ssl.internal.ssl.Provider() );
    public static void main(String[] args) throws RemoteException {
         Connection con=new Connection();
         AaaServiceStub connectionStub=con.connectionStub();
        AB=con.Login();
        System.out.println("AB="+con.Login());
  // con.Logout(A;
    public AaaServiceStub connectionStub() throws AxisFault
        connectionStub =  new AaaServiceStub(locserverurl+"aaa/");
            return connectionStub;
    public LocationServiceStub stub() throws AxisFault
        stub =  new LocationServiceStub(locserverurl+"location/");
            return stub;
public AesBusinessSession Login() throws AxisFault{
     try{
            //Login into the Location Server
            AesLogin AL = AesLogin.Factory.newInstance();
            AL.setUserName(locserveruserName);
            AL.setPassword(locserverPassword);
            LoginMethodArgs LM = LoginMethodArgs.Factory.newInstance();
            LM.setAesLogin(AL);
            LoginDocument LD = LoginDocument.Factory.newInstance();
            LD.setLogin(LM);
            SessionDocument session = connectionStub().Login(LD);
            if (session!=null)
                System.out.println(session);
                AB= session.getSession().getAesBusinessSession();
            else{
                System.out.println("Login Failed");
         catch (Exception e) {
                e.printStackTrace();
    return AB;
public ResponseDocument Logout(AesBusinessSession A throws RemoteException{
    //Logout
    LogoutMethodArgs LMA = LogoutMethodArgs.Factory.newInstance();
    LMA.setAesBusinessSession(A;
    LMA.addNewAesLogout();
    LogoutDocument logout = LogoutDocument.Factory.newInstance();
    logout.setLogout(LMA);
    ResponseDocument r = connectionStub().Logout(logout);
    System.out.println(r);
    if(r==null){
        System.out.println("LOGOUT FAILED");
    return r;
Waiting for your reply. Please Help.
Amlan
Replied by: amlan dutta on 23-08-2010 12:25:57 PM
Thanks a lot for your reply. I am not in a VPN. I can ping the simulator from terminal of my machine and vice versa. I have also added all the axis2.jars in build path. Still didnt able to connect my MSE. Please help.
Amlan
Hi Amlan,
Matt
Content for Community-Ad
Cisco Community August2020 Spotlight Award Winners
