Highlighted
Beginner
6VPE doesn't work: VRF address family ipv6 is not supported or not enabled
Hi all
I am just about to migrate our first customer vrf to dual-stack operation. Everything is easy to migrate and is working fine as long as I am dealing with the "small" 72xx and 28xx routers.
When it comes to our PE routers the trouble begins:
For our Cat6509 with Sup720/MSFC3 the Cisco software advisor is telling me that 6VPE is provided since 12.2(33)SXI minimum. Well, first I have tried to activate address-family ipv6 in a vrf definition on a machine running SXI1. Whenever I want to activate address-family ipv6 in the vrf definition I get
"VRF address family ipv6 is not supported or not enabled"
Another machine in the lab is running latest SXI5. But guess what, I get exactly the same reaction here.
So where is my mistake?
Grischa
1 ACCEPTED SOLUTION
Highlighted
Do you have the following configured?
ipv6 unicast-routing
mls ipv6 vrf
If not then configure them and try again.
Atif
2 REPLIES 2
Highlighted
mls ipv6 vrf
Atif
Highlighted
Hi Atif
That's it. I had the first of course but forgot about the last.
Thank you very much,
Grischa
Content for Community-Ad
