7600 reload when online insert card
I met this problem about 5% of my 7600 routers but not everytime. How should I do?
Last node yesterday no any abnormal log and no crash file. It have 3 cards: RSP720, 6704 (online inserted), and 6724 card.
Thank you very much.
6 Replies 6
Vinit Jain
Could you please share the show log and show diagn events. Also, note that, if the cards are not inserted properly or there is too much of delay in inserting the cards, this can cause backplane issues and cause the cards to flap.
Once you share the logs, i will look into it.
Vinit
--Vinit
Also, note that, if the cards are not inserted properly or there is too much of delay in inserting the cards, this can cause back-plane issues and cause the cards to flap.
I agree. Do you have any document?
I will have to look through to find a relevant document but i can suggest you as a best practice, you can first disable the power on the module by configuring the command:
no power enable module <module #>
Once the module is inserted, you can then re-enable the power back for the slot.
i would still request you to share the below logs:
- show log
- show diagn events
Please note that the logs should be present for the time when the modules crashed.
Hope this helps.
Vinit
--Vinit
p2#sh diagnostic events
Diagnostic events (storage for 500 events, 3 events recorded)
Event Type (ET): I - Info, W - Warning, E - Error
Time Stamp         ET [Card] Event Message
05/09 18:10:31.012 I  [5] Diagnostics Passed
05/09 18:11:23.681 I  [9] Diagnostics Passed
05/09 18:11:30.217 I  [1] Diagnostics Passed
p2#
For log, could you please share your email?
You can attach the show log as a file when you reply. there is an option for attachment.
Vinit
--Vinit
Sorry, I wouldn't like it shows to the public.
