7613, PBR Inside an VRF
p.diaz
Hi Everybody.
I like to know if it's possible to configure PBR inside an vrf in an 7613 series router with the IOS: s72033-adventerprisek9_wan-mz.122-33.SRA5.bin.
I Like to configure that some traffic coming from some ip addresess goes to an specified interface.
I appreciate everything.
royalblues
Level 10
Level 10
You can configure PBR and select the VRF the packets need to be placed.
http://www.cisco.com/en/US/docs/ios/12_2sr/12_2srb/feature/guide/srb2mvrf.html
In your case you can define only one receive VRF under the interface and define next hops within the PBR
Narayan
Laurent Aubert
I think VRF-Lite aware PBR is supported starting SRC
Laurent.
