03-30-2015 11:05 AM
Howdy,
So I have a small issue in my lab.
I have setup H-VPLS with BGP autodiscovery.
All cicruits are up, everything seems great.
Problem is I only get 1 way traffic. From Test_A, I see the mac address from Test_B. I dont see the other way round.
However, in the bridge-domain on Test_B device, I see the mac address entry no problem.
U-PE has xconnect to PE_B. from there i have configured auto-discovery and this session goes to PE_A where the other IP address lives.
From Site A
Local interface: VFI Testcustomer1 vfi up
Interworking type is Ethernet
Destination address: 4.4.4.4, VC ID: 5, VC status: up
Output interface: Gi0/1, imposed label stack {18 25}
Preferred path: not configured
Default path: active
Next hop: 10.10.10.9
Create time: 00:21:58, last status change time: 00:21:58
Last label FSM state change time: 00:21:58
Signaling protocol: LDP, peer 4.4.4.4:0 up
Targeted Hello: 1.1.1.1(LDP Id) -> 4.4.4.4, LDP is UP
Graceful restart: not configured and not enabled
Non stop routing: not configured and not enabled
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: No fault
Last local PW i/f circ status rcvd: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 27, remote 25
AGI: type 1, len 8, 000A 1999 0000 0005
Local AII: type 1, len 4, 0101 0101 (1.1.1.1)
Remote AII: type 1, len 4, 0404 0404 (4.4.4.4)
Group ID: local n/a, remote n/a
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
Dataplane:
SSM segment/switch IDs: 16427/4134 (used), PWID: 1
VC statistics:
transit packet totals: receive 0, send 0
transit byte totals: receive 0, send 0
transit packet drops: receive 0, seq error 0, send 0
From Site B
Internet 20.0.0.2 0 Incomplete ARPA
but i see the mac on the bridge domain group
5 44ad.d94d.8444 DYNAMIC 4.4.4.4, 5
Local interface: Vl5 up, line protocol up, Eth VLAN 5 up
Output interface: Gi0/24, imposed label stack {28}
Next hop: 10.10.10.13
Create time: 00:21:14, last status change time: 00:21:08
Last label FSM state change time: 00:21:08
Targeted Hello: 5.5.5.5(LDP Id) -> 4.4.4.4, LDP is UP
MPLS VC labels: local 24, remote 28
Group ID: local 0, remote 0
Dataplane:
SSM segment/switch IDs: 8241/4143 (used), PWID: 1
VC statistics:
Any ideas welcome!
04-09-2015 05:59 AM
issue was with the hardloop.
Testing with physical PC's works. Weird
