Octavio Alfageme
Beginner
ATOMoGRE unidirectional forwarding (7609-RSP720-ES+ card)
Dear all,
I would be grateful if somebody could give me any idea about the behavior I have in my network. I have configured ATOMoGRE between two 7609s in the following way.
* GRE tunnel endpoints are:
a. ROUTER1: 7609 RSP720 (IOS 15.2(4)S1) GE interface in a ES+ card (router running in PFC3BXL mode, as it has a SIP600 card equipped)
b. ROUTER2: 7609 RSP720 (IOS 15.2(4)S1) POS interfaces in a SIP400 (router running in PFC3CXL mode)
* MPLS-TE engineering is enabled in the GRE tunnel and RSVP signalled LSP inside the tunnel is up and running. I use affinity-bits to set the LSP's path.
* Pseudowire between two EVCs in ports of ES+ cards is created and it seems to be properly signalled by T-LDP
Traffic is sent in the VC from a CE connected to ROUTER1 and received by a CE connected to ROUTER2 (remote CE's ARP entry is completed in ROUTER2). However, traffic sent from ROUTER2's CE inside the VC is not received by ROUTER1's CE. This traffic is accounted as sent by the ROUTER2's VC endpoint. We can see it in the VC statistics:
ROUTER1#show mpls l2transport vc 1000 detail
Local interface: Gi8/3 up, line protocol up, Ethernet:10 up
  Destination address: 10.10.10.2, VC ID: 1000, VC status: up
    Output interface: Tu103, imposed label stack {24}
    Preferred path: Tunnel103,  active
    Default path:
    Next hop: point2point
  Create time: 1d09h, last status change time: 1d09h
    Last label FSM state change time: 1d09h
  Signaling protocol: LDP, peer 10.10.10.2:0 up
    Targeted Hello: 10.10.10.1(LDP Id) -> 10.10.10.2, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: No fault
      Last local AC  circuit status sent: No fault
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 31, remote 24
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  SSO Descriptor: 10.10.10.2/1000, local label: 31
  Dataplane:
    SSM segment/switch IDs: 7302/15493 (used), PWID: 16
  VC statistics:
    transit packet totals: receive 0, send 25   <----- no packets received in ROUTER1
    transit byte totals:   receive 0, send 1700
    transit packet drops:  receive 0, seq error 0, send 0
ROUTER2#show mpls l2transport vc 1000 det
Local interface: Gi8/2 up, line protocol up, Ethernet:10 up
  Destination address: 10.10.10.1, VC ID: 1000, VC status: up
    Output interface: Tu103, imposed label stack {31}
    Default path:
  Create time: 1d22h, last status change time: 1d09h
  Signaling protocol: LDP, peer 10.10.10.1:0 up
    Targeted Hello: 10.10.10.2(LDP Id) -> 10.10.10.1, LDP is UP
    MPLS VC labels: local 24, remote 31
  SSO Descriptor: 10.10.10.1/1000, local label: 24
  Dataplane:
    SSM segment/switch IDs: 23454/11162 (used), PWID: 15
  VC statistics:
    transit packet totals: receive 65, send 96 <---- ROUTER2's endpoint seems to have bidirectional connectity
    transit byte totals:   receive 3900, send 7878
* "mls mpls tunnel-recir" is enabled in both routers.
* It's not a MTU problem, as I'm testing the connectivity with small pings from the CEs.
* Might there be a support problem of ATOMoGRE in PFC3BXL mode (ROUTER1)?
Any idea will be welcomed, as I don't understand this behaviour.
Thank you in advance
Octavio
2 REPLIES 2
Andre Gustavo Albuquerque
I am not sure whether this particular use case is supported or not...
Would L2TPv3 be an option for you?
If so, you could use it as the transport tunnel instead of mpls/gre.
See more info at http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wp1731928
Cheers
Thank you very much, Andre.
L2TPv3 wouldn't be my first option (I also use the GRE tunnel for native IP traffic), but I tested it following the instructions you sent and I can confirm that it works fine, so I suppose it would be my choice for layer 2.
In any case, I will go on with my ATOMoGRE tests (changing tunnel source to loopback interfaces, configuring tunnels as unnumbered, ...), as I would like to find an explanation for the odd behaviour I see. In case I get any result I will report it within this thread.
Thanks a lot for your help
Octavio
