Bandwith Provisioning
obaroikoh
I have three routers connected via point to multi point (R1 to R2 and R3). I want to split the bandwith i'm getting from my ISP between R2 and R3. R1 is connected to my ISP. what do i do? Thanks
Heres's a use case. I'm getting 2Mbps from my ISP coming into R1, and i want to split it into two. 1Mbps to go to R2 and the remaining 1Mbps to R3
vik_20000
SO your topology looks like this?
R1--------R2
R1--------R3
what links you  you using ? and also what protocols are running between ISP-R1 and R1-R2/R1-R3 ? may be you can use speed OR bandwidth command on interface .
