Basic MPLS L3 VPN problem
roger perkin
Level 2
Level 2
I have setup a basic MPLS lab and am trying to get R1 and R11 to run RIP over the VRF PALM
I am running OSPF inside and BGP between PE1 and PE2
I believe why R1 cannot ping R11 is that routes are not being passed between BGP because of the same AS?
PE1:
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 55.55.55.55 remote-as 1
neighbor 55.55.55.55 update-source Loopback1
no auto-summary
address-family vpnv4
  neighbor 55.55.55.55 activate
  neighbor 55.55.55.55 send-community extended
  neighbor 55.55.55.55 allowas-in
exit-address-family
address-family ipv4 vrf PALM
  redistribute rip
  no synchronization
exit-address-family
router rip
version 2
  redistribute connected
  redistribute bgp 1 metric 0
  network 192.168.13.0
  no auto-summary
  version 2
exit-address-family
PE2:
router bgp 1
no synchronization
neighbor 33.33.33.33 remote-as 1
neighbor 33.33.33.33 update-source Loopback1
no auto-summary
  neighbor 33.33.33.33 activate
  neighbor 33.33.33.33 send-community extended
  neighbor 33.33.33.33 allowas-in
exit-address-family
  redistribute rip
  no synchronization
exit-address-family
router rip
version 2
  network 192.168.115.0
  no auto-summary
  version 2
exit-address-family
The RIP routes are in the VRF on both PE1 and PE2 but they are not making it between them.
I am sure I am missing a redistribute command between RIP and BGP and possibly a AS issue,
I have probably put the redistribute in the wrong place? not exactly sure about VRF's etc.
Thanks for any help
Roger
5 Replies 5
Nagendra Kumar Nainar
Do you have the RT import/export configuration as required?. Can you get the configuration from both PE devices along with "show ip bgp vpnv4 all" output.
Nagendra
PE1#show ip bgp vpnv4 all
BGP table version is 7, local router ID is 33.33.33.33
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 111:111 (default for vrf PALM)
*> 1.0.0.0          192.168.13.1             1         32768 ?
*> 11.0.0.0         192.168.13.1             1         32768 ?
*> 192.168.13.0     0.0.0.0                  0         32768 ?
PE1#
PE1#
PE1#sh run
Building configuration...
Current configuration : 2187 bytes
version 12.4
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip vrf PALM
rd 111:111
route-target export 111:111
route-target import 111:111
mpls label protocol ldp
mpls ldp neighbor 44.44.44.44 password cisco
interface Loopback0
ip address 3.3.3.3 255.255.255.0
interface Loopback1
ip address 33.33.33.33 255.255.255.0
interface Ethernet0/0
ip address 192.168.34.3 255.255.255.0
half-duplex
mpls ip
interface Ethernet0/1
no ip address
half-duplex
interface Ethernet0/2
ip vrf forwarding PALM
ip address 192.168.13.3 255.255.255.0
half-duplex
interface Ethernet0/3
ip address 192.168.23.3 255.255.255.0
half-duplex
interface Ethernet1/0
ip address 192.168.36.3 255.255.255.0
half-duplex
interface Ethernet1/1
no ip address
half-duplex
interface Ethernet1/2
no ip address
shutdown
half-duplex
interface Ethernet1/3
no ip address
shutdown
half-duplex
router ospf 1
log-adjacency-changes
redistribute rip
passive-interface default
no passive-interface Ethernet0/0
network 3.3.3.3 0.0.0.0 area 0
network 33.33.33.33 0.0.0.0 area 0
network 192.168.34.3 0.0.0.0 area 0
router rip
version 2
  no auto-summary
  version 2
exit-address-family
router bgp 1
address-family ipv4
  redistribute rip
  no auto-summary
  no synchronization
exit-address-family
exit-address-family
  redistribute rip
  no synchronization
exit-address-family
ip http server
ip forward-protocol nd
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
PE2#sh ip bgp vpnv4 all
BGP table version is 5, local router ID is 55.55.55.55
*> 111.0.0.0        192.168.115.11           1         32768 ?
*> 192.168.115.0    0.0.0.0                  0         32768 ?
PE2#sh run
Current configuration : 2189 bytes
version 12.4
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip vrf PALM
rd 111:111
interface Loopback0
ip address 5.5.5.5 255.255.255.0
ip ospf network point-to-point
interface Loopback1
ip address 55.55.55.55 255.255.255.0
ip address 192.168.45.5 255.255.255.0
half-duplex
mpls ip
ip address 192.168.57.5 255.255.255.0
half-duplex
ip address 192.168.58.5 255.255.255.0
half-duplex
ip address 192.168.115.5 255.255.255.0
half-duplex
ip address 192.168.125.5 255.255.255.0
half-duplex
ip address 192.168.105.5 255.255.255.0
half-duplex
no ip address
shutdown
half-duplex
no ip address
shutdown
half-duplex
router ospf 1
redistribute rip
network 5.5.5.5 0.0.0.0 area 0
network 55.55.55.55 0.0.0.0 area 0
network 192.168.45.5 0.0.0.0 area 0
router rip
version 2
  no auto-summary
  version 2
exit-address-family
router bgp 1
address-family ipv4
  redistribute rip
  no auto-summary
  no synchronization
exit-address-family
exit-address-family
  redistribute rip
  no synchronization
exit-address-family
ip http server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
PE2#
Roger,
This reminds me of a similar setup I've done a few months ago. My case is a bit different but here goes my config (I had to change IP address, but hopefully didn't destroy consistency)
sh run | s r b
router bgp 100
no bgp default ipv4-unicast
neighbor 192.2.5.5 remote-as 100
neighbor 192.2.5.5 update-source Loopback0
neighbor 192.2.6.6 remote-as 100
neighbor 192.2.6.6 update-source Loopback0
  neighbor 192.2.5.5 activate
  neighbor 192.2.5.5 send-community extended
  neighbor 192.2.5.5 route-reflector-client
  neighbor 192.2.6.6 activate
  neighbor 192.2.6.6 send-community extended
  neighbor 192.2.6.6 route-reflector-client
exit-address-family
address-family ipv4 vrf VPN_B
  redistribute rip
  no synchronization
exit-address-family
sh run | s r r
router rip
version 2
  redistribute bgp 100 metric transparent
  network 192.168.1.0
  no auto-summary
exit-address-family
sh ip bgp vpnv4 vrf VPN_B
BGP table version is 31, local router ID is 192.2.4.4
Route Distinguisher: 0:2 (default for vrf VPN_B)
*>i0.0.0.0          192.2.6.6                0    100      0 ?
*>i192.2.7.7/32     192.2.6.6                0    100      0 78 i
*>i192.2.8.0/24     192.2.6.6                0    100      0 78 i
*>i192.2.55.55/32   192.2.5.5                0    100      0 i
*>i192.2.66.66/32   192.2.6.6                0    100      0 i
*>i192.1.5.0/24     192.2.5.5                0    100      0 ?
*>i192.1.58.0/24    192.2.5.5                0    100      0 ?
*>i192.1.67.0/24    192.2.6.6                0    100      0 ?
*>i192.1.76.0/24    192.2.6.6                0    100      0 ?
*>i192.1.68.7.0      192.2.6.6                0    100      0 ?
* i                 192.2.6.6                1    100      0 ?
*> 192.1.68.1.0       0.0.0.0                  0         32768 ?
sh ip rip data vrf VPN_B
0.0.0.0/0    auto-summary
0.0.0.0/0    redistributed
    [1] via 192.2.6.6,
192.2.0.0/16    auto-summary
192.2.7.7/32    redistributed
    [1] via 192.2.6.6,
192.2.8.0/24    redistributed
    [1] via 192.2.6.6,
192.2.55.55/32    redistributed
    [1] via 192.2.5.5,
192.2.66.66/32    redistributed
    [1] via 192.2.6.6,
192.1.0.0/16    auto-summary
192.1.5.0/24    redistributed
    [1] via 192.2.5.5,
192.1.58.0/24    redistributed
    [1] via 192.2.5.5,
192.1.67.0/24    redistributed
    [1] via 192.2.6.6,
192.1.76.0/24    redistributed
    [1] via 192.2.6.6,
192.1.68.7.0/24    auto-summary
192.1.68.7.0/24    redistributed
    [1] via 192.2.6.6,
192.1.68.1.0/24    auto-summary
192.1.68.1.0/24    directly connected, FastEthernet0/0
In anyway I would check if those prefixes are redistributed into RIP as the next step ;-)
Marcin
One Pe2 side, you appears to be missing with route-target import and export. Can you try that and see if it works?.
Nagendra
If you are using same AS on both sides, you have to override the AS number.
http://fengnet.com/book/MPLS%20Configuration%20on%20Cisco%20IOS%20Software/ch06lev1sec1.html
