bgp allowas-in
sachin30720041
Beginner
Beginner
I have following setup. CE3 and CE4 are running bgp as a PC-CE protocol. CE3 and CE4 are configured in AS 34. routes are not exchanged between CE3 and CE4. Although I have configured 'allowas-in' on both CE3 and CE4.  VPNV4 routes are exchanged between PE1 and PE2.
CE3-------PE1----PE2----CE4
Configuration:-
ios3
int gi0/0
ip address 100.10.30.3 255.255.255.0
no sh
int lo0
ip address 3.3.3.3 255.255.255.255
router bgp 34
bgp router-id 3.3.3.3
template peer-session session12
remote-as 12
exit
neighbor 100.10.30.1 inherit peer-session session12
address-family ipv4 unicast
network 3.3.3.3 mask 255.255.255.255
neighbor 100.10.30.1 activate
neighbor 100.10.30.1 allowas-in
exit
XRV1
vrf vrf1
export route-target 1:1
import route-target 2:2
exit
int gi0/0/0/0
vrf vrf1
ip address 100.10.30.1 255.255.255.0
no sh
int gi0/0/0/1
ip address 100.10.20.1 255.255.255.0
no sh
int lo0
ipv4 address 1.1.1.1 255.255.255.255
router isis 1
net 49.0001.1111.1111.1111.00
is-type level-2
metric-style wide
mpls ldp auto-config
exit
int gi0/0/0/1
exit
int lo0
exit
exit
route-policy pass
pass
exit
mpls ldp
exit
router bgp 12
exit
address-family vpnv4 unicast
exit
neighbor-group group12
remote-as 12
update-source lo0
exit
neighbor-group group34
remote-as 34
route-policy pass in
route-policy pass out
exit
neighbor 2.2.2.2
use neighbor-group group12
vrf vrf1
rd 1:1
exit
neighbor 100.10.30.3
use neighbor-group group34
XRV2
vrf vrf1
export route-target 2:2
import route-target 1:1
exit
int gi0/0/0/0
vrf vrf1
ip address 100.20.40.2 255.255.255.0
no sh
int gi0/0/0/1
ip address 100.10.20.2 255.255.255.0
no sh
int lo0
ipv4 address 2.2.2.2 255.255.255.255
mpls ldp
exit
router isis 1
net 49.0002.2222.2222.2222.00
is-type level-2
metric-style wide
exit
int gi0/0/0/1
exit
int lo0
exit
exit
route-policy pass
pass
exit
router bgp 12
bgp router-id 2.2.2.2
exit
exit
remote-as 12
update-source lo0
exit
remote-as 34
exit
neighbor 1.1.1.1
vrf vrf1
rd 1:1
exit
neighbor 100.20.40.4
ios4
int gi0/0
ip address 100.20.40.4 255.255.255.0
no sh
int lo0
ip address 4.4.4.4 255.255.255.255
router bgp 34
remote-as 12
exit
neighbor 100.20.40.2 inherit peer-session session12
network 4.4.4.4 mask 255.255.255.255
neighbor 100.20.40.2 activate
neighbor 100.20.40.2 allowas-in
exit
Harold Ritter
Hi @sachin30720041 ,
IOS-XR does the outbound AS path loop check by default. You can configure the following command to disable it.
router bgp 12
 vrf vrf1
   as-path-loopcheck out disable
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Harold Ritter
router bgp 12
 vrf vrf1
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Recognize Your Peers
