Can configure layer 2 interface at 7600+rsp720+sip400+SPA-2X1GE-V2
Ru Song Fu
HI guys:
SPA-2X1GE-V2 module interface can work L2 switchport?Thank's
same:
interface GigabitEthernet5/1/1
switchport
switchport access vlan 20
switchport mode access
rsimoni
Hi there,
no the SIP400 cannot be configured as L2 switchport (it does not make any difference which SPA you actually use).
However you can have multipoint Layer 2 bridging service by using bridge-domain under service instance configuration (EVC)
something like:
service instance 1 ethernet
  encapsulation dot1q 20
  bridge-domain 20
Internally one bridge-domain is mapped to one of the 4K global VLAN resource; meaning that you still need a SVI for the L3 termination.
i.e:
Interfaca vlan 20
ip address 10.0.0.0 255.255.255.0
regards,
Riccardo
Thank U!
you are welcome.
please rate and close the question if useful
Riccardo
