Does SR-TE policy have a path protection function?
Soushi Takata
Thanks for any insight.
I want to move from RSVP-TE to SR-TE policy.
The RSVP-TE environment uses the path protection function.
I would like to use the path protection feature in the SR-TE policy environment as well.
But I could not find any such feature in the configuration guide or etc.
Is it possible to implement the path protection function in SR-TE policy?
Soushi
5 Replies 5
Soushi,
SR-TE can leverage TI-LFA and Remote TI-LFA. It's easily configurable under ISIS/OSPF. I found the official SR website has most of the info and detailed guide about it. I would also recommend getting the SR I and II books if you want to learn even more.
https://www.segment-routing.net/tutorials/2016-09-27-topology-independent-lfa-ti-lfa/
Cheers, L.
Ioris,
Thank you for your reply.
I know Segment Routing can use TI-LFA.
And I think TI-LFA is a good feature as Local Repair.
However, what I am looking for is a global repair function.
Because I want to migrate the RSVP-TE configuration directly to SR-TE, if possible.
I remember there was a path-protection command when sr-te was using tunnel interface.
Best Regards,
interface tunnel-te1
ipv4 unnumbered Loopback0
bfd
fast-detect sbfd
multiplier 3
minimum-interval 50
destination 1.1.1.2
path-protection
path-option 10 explicit name PRIMARY segment-routing protected-by 20
path-option 20 explicit name SECONDARY segment-routing protected-by 10
Is this what you are looking for?
Ioris,
It's this config that I wrote that I remember.
However, this configuration cannot be set in the current IOS-XR.
We can't specify segment-routing in the path-option setting.
Now we need to configure the policy in the segment routing section.
segment-routing
traffic-eng
segment-list LIST1
index 20 mpls label 16004
index 30 mpls label 16002
policy 1
color 101 end-point ipv4 1.1.1.2
candidate-paths
preference 50
explicit segment-list LIST1
And as far as I know, there's no path-protection setting here.
So I'm looking for a way to configure path-protection.
Best regards,
Ah.. got it! Yes not sure there's anything like that in SR Auto Steering or
ODN policy.
Let's see if anyone knows more, now I am also curious.
Cheers L
