09-16-2014 03:35 AM
Cisco ASR 901
Cisco A901-12C-FT-D
asr901-universalk9-mz.154-2.S.bin
(config-if)#mtu ?
<64-1500> MTU size in bytes
Нow to increase up to 1516 (for MPLS)
Solved! Go to Solution.
09-19-2014 08:06 AM
Hi Mick,
Can you try override keyword if it works in your case..
(config-if)#mpls mtu ?
<64-1500> MTU (bytes)
override Override mpls mtu maximum of interface mtu
SWP-ACC-SIX(config-if)#mpls mtu override ?
<1501-1580> MTU (bytes) ================> mtu is 1500 and mpls mtu can be configured upto 1580.
--Pls dont forget to rate helpful posts--
Mohit
09-19-2014 08:06 AM
Hi Mick,
Mohit
09-22-2014 06:46 AM
Thank you, msahai!
#mpls mtu override 1516 ---- IT WORKS
