EIGRP MPLS
jrcabanes
Hi guys, just like to ask about using EIGRP on MPLS. I have a scenario in which EIGRP was used between the MPLS PE to CE routing on our MPLS network. The network looks like this: the customer have connections to our MPLS cloud, and we used EIGRP for PE-CE as per their requirements. They have a backup link via leased lines with another provider, and they are also using EIGRP in the same AS on those links. The problem is, all routes point to the backup link rather than the MPLS cloud. Do we have a good solution for this? Thanks ini advance.
Harold Ritter
The BGP cost community is the way to address this issue when you use EIGRP between the PE and CE. For more information on this feature, please refer to the following url:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1829/products_feature_guide09186a00801bbad4.html
Hope this helps,
Thanks hritter.
