EoMPLS between Cisco 7604 and ASR 9000
Yuriy12345
Dear collegues
We have Cisco  7604 and ASR 9000 connected together via 10GE interface. Our 7604 has  ES+ core-facing module and not ES+ on AC side.
We are implementing EoMPLS between them but VC doesn't come up.
Does anyone have some consideration about what the problem is?
We have following connections:
Catalyst 3750 <---->  Ge 1/2 Cisco 7604 TE 4/4 <----> Te0/0/0/0 ASR9000 Te0/0/0/1 <----> ME 3600
Here is the output os show ... command
7604#sh module
Mod Ports Card Type                              Model
  1    2  Route Switch Processor 720 (Active)    RSP720-3C-GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  3   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP
  4    4  7600 ES+T                              76-ES+T-4TG
7604# sh mpls l2transport vc 2 detail
Local interface: Gi1/2.528 up, line protocol up, Eth VLAN 528 up
  Destination address: 10.1.0.1, VC ID: 2, VC status: down
    Output interface: Te4/4, imposed label stack {16002}
    Preferred path: not configured
    Default path: active
    Next hop: 10.1.1.1
  Create time: 04:14:29, last status change time: 00:22:04
  Signaling protocol: LDP, peer 10.1.0.1:0 up
    Targeted Hello: 10.1.0.2(LDP Id) -> 10.1.0.1, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRrd
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: DOWN(PW-tx-fault)
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: DOWN(PW-tx-fault)
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 17, remote 16002
    PWID: 20639
    Group ID: local 0, remote 67109120
    MTU: local 9202, remote 9202
    Remote interface description: TenGigE0_0_0_1.100
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  SSO Descriptor: 10.1.0.1/2, local label: 17
    SSM segment/switch IDs: 8353/12403 (used), PWID: 20639
  VC statistics:
    transit packet totals: receive 0, send 2
    transit byte totals:   receive 0, send 180
    transit packet drops:  receive 0, seq error 0, send 0
RP/0/RSP0/CPU0:ASR9000#sh l2vpn xconnect detail
Tue Feb 14 08:51:13.163 UTC
Group Backbone1, XC to7604, state is down; Interworking none
  AC: TenGigE0/0/0/1.100, state is up
    Type VLAN; Num Ranges: 1
    VLAN ranges: [100, 100]
    MTU 9202; XC ID 0x840001; interworking none
    Statistics:
      packets: received 0, sent 0
      bytes: received 0, sent 0
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 10.1.0.2, PW ID 2, state is down ( remote standby )
    PW class dynamic_mpls, XC ID 0xc0000001
    Encapsulation MPLS, protocol LDP
    Source address 10.1.0.1
    PW type Ethernet VLAN, control word enabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    PW Status TLV in use
      MPLS         Local                          Remote
      Label        16002                          17
      Group ID     0x4000100                      0x0
      Interface    TenGigE0/0/0/1.100             unknown
      MTU          9202                           9202
      Control word enabled                        enabled
      PW type      Ethernet VLAN                  Ethernet VLAN
      VCCV CV type 0x2                            0x12
                   (LSP ping verification)        (LSP ping verification)
      VCCV CC type 0x7                            0x6
                   (control word)
                   (router alert label)           (router alert label)
                   (TTL expiry)                   (TTL expiry)
    Incoming Status (PW Status TLV):
      Status code: 0x0 (Up) in Notification message
    Outgoing Status (PW Status TLV):
      Status code: 0x10 (PW Down) in Notification message
    MIB cpwVcIndex: 3221225473
    Create time: 14/02/2012 08:26:46 (00:24:26 ago)
    Last time status changed: 14/02/2012 08:27:57 (00:23:15 ago)
    Statistics:
Rurick Kellermann
Yuriy,
In addition to these commands, you should review the MPLS Label (Outer Label) assigned by the MPLS network to the Xconnect  to determine if it is using LDP or if is using a TE-Tunnel,  MLS CEF (on the 7600) and the output of debug commands for the xconnect.
Note: Depending on the amount of Xconnects in your network, it's recommended to perform conditional debugging to limit the amount of debug data (i.e. debug interface Te4/4, followed by specific debug commands).
On the 7600:
- show mpls forwarding table | i 16002
- show mls cef mpls labels 16002
- show mls cef adjacency entry 16002 detail
- debug interface Te4/4
- debug mpls l2transport vc status event
- debug mpls l2transport vc status fm
Additional details available at :
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap6.html
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.0/troubleshooting/guide/tr40l2v.html
Let us know if you'd prefer to continue troubleshooting with you.
Rurick, thank you for your answer!
We solved the problem.
I used static routing to reach loopbacks, and when I configured OSPF between 7604 and asr9k VC came up.
