06-03-2017 07:40 AM
Hi everybody,
I do not have access to right gear, have a question :
Please consider the following config and scenario:
CE------f0/0 R2--MPLS CORE
R2:
interface f0/0
no ip address
switchport
switchport access vlan 800
switchport mode dot1qtunnel
interface vlan 800
no ip address
x connect 1.1.1.1 2 encapsulation mpls
Let say CE sends a packet , which is received by R2 on f0/0.
1) Will R2 tag the traffic with vlan tag 800 when sending traffic over PW to remote PE 1.1.1.1?
Thanks and have a nice weekend!!
Solved! Go to Solution.
06-07-2017 03:40 PM
As soon as your traffic passes through the dot1q tunnel, you'll have an action tag corresponding to your dot1q tunnel Vlan (vlan provider). In your case you'll see 2 tags : your real vlan id + dot1q tunnel vlan 800.
PS: Please don't forget to rate and mark as correct answer if this answered your question
06-12-2017 07:23 AM
You're welcome sarahr202 !!
06-07-2017 03:40 PM
06-12-2017 07:20 AM
Thanks Francesco!!
06-12-2017 07:23 AM
