how can i match exp on WRR
flyjunli
on 6724 line card,we can't use bandwidth and priority command on output service-plicy, so we try to use WRR command. i can match cos, but how can i match EXP.
If we use WRR, can we get same result/behavior as MQC bandwidth priority command on output direction.
can we use match cos on P router.
thank you!
Fly
carenas123
Level 5
Level 5
Yes you can use WRR command.
Follow the URL for the for the further description of the command guide it may help you
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/command/reference/V1.html
