03-02-2019 02:02 AM
Hi dears
i was trying to bult OPtion A lab and faced a problem
i saw it was discussed in this forum to be frank i folowed the suggestions about ospf vrf light capabilities but still have some troubles
may be someone can tell mw what is wrong
the network is quite simple but i can't redistrubite routes on the ASBRs from ospf to bgp (address familiy etc.) and vise versa
i attached to the post GNS3 files , could you please check
thanks in advance
Solved! Go to Solution.
03-05-2019 06:06 AM
Assuming they will be external OSPF routes you are trying to redistribute into BGP......well, you need to tell BGP explicitly to redistribute external routes. By default it only does intra/inter area routes.
So try something like:
redistribute ospf 1 match internal external 1 external 2
and see how you get on.
03-05-2019 06:06 AM
03-06-2019 10:50 PM
03-06-2019 11:06 PM
hi thanks a lot i found the doccument convering redistribution process of ospf into bgp
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/5242-bgp-ospf-redis.html
thanks a lot .
