Inter-as option C with same IGP + LDP
isacco.fontana
we're activating new bgp AS number inside our backone using the same IGP + LDP cloud. We already activated the RR and mp-bgp for new AS number. We would like to use the inter-as option C (peering between RR) to transport VPN and mVPN (v4/v6) between AS to garant good interworking but use only peering between RR. The Inter-as option C need also peering BGP+label between ASBR to transport routes and label but we prefer to use the IGP + LDP (ospf/ldp) to do it.
I appreciate some suggestion about this issue.
Thanks for support
Isacco
Mahesh Gohil
Level 7
Level 7
Hi Issaco,
Just few days ago I have tested option-B and option-C on GNS. I am attaching that document here which might be useful to you.
Hope this helps.
Regards # Mahesh
