Community Helping Community
272
Beginner
ISR 4321-MPLS is not setting labels
I have an issued with a mpls connections, which apparently is not setting mpls labels, everythins seems to be correctly configured but when it trace the destinatio ip, it doesnt show anythin
TFE-D-L2L4724-#trace mpls ipv4 10.206.1.119/32 source 10.206.1.120
Tracing MPLS Label Switched Path to 10.206.1.119/32, timeout is 2 seconds
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
'L' - labeled output interface, 'B' - unlabeled output interface,
'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
'P' - no rx intf label prot, 'p' - premature termination of LSP,
'R' - transit router, 'I' - unknown upstream index,
'l' - Label switched with FEC change, 'd' - see DDMAP for return code,
'X' - unknown return code, 'x' - return code 0
0 10.206.1.120 MRU 0 [No Label]
Q 1 *
TFE-D-L2L4724#
TFE-D-L2L4724#sh mpls forwarding-table 10.206.1.119
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
None No Label 10.206.1.119/32 0 Gi0/0/0.3776 10.178.179.129
TFE-D-L2L4724#sh mpls ldp dis
Local LDP Identifier:
10.206.1.120:0
Discovery Sources:
Interfaces:
GigabitEthernet0/0/0.3776 (ldp): xmit/recv
LDP Id: 10.206.16.17:0
LDP Id: 10.149.100.16:0; no route
LDP Id: 10.59.243.132:0
TFE-D-L2L4724#sh mpls ldp nei
Peer LDP Ident: 10.59.243.132:0; Local LDP Ident 10.206.1.120:0
TCP connection: 10.59.243.132.646 - 10.206.1.120.31442
State: Oper; Msgs sent/rcvd: 1064/3174; Downstream
Up time: 03:14:43
LDP discovery sources:
GigabitEthernet0/0/0.3776, Src IP addr: 10.178.179.129
Addresses bound to peer LDP Ident:
10.59.243.132 10.205.95.21 10.101.245.129 10.179.50.198
10.149.83.1 10.101.79.221 10.148.128.1 10.179.67.27
10.172.193.1 10.172.193.65 10.175.179.129 10.178.179.129
Peer LDP Ident: 10.206.16.17:0; Local LDP Ident 10.206.1.120:0
TCP connection: 10.206.16.17.51121 - 10.206.1.120.646
State: Oper; Msgs sent/rcvd: 230/229; Downstream
Up time: 03:14:43
GigabitEthernet0/0/0.3776, Src IP addr: 10.178.179.143
10.178.179.143 10.206.16.17
TFE-D-L2L4724#sh mpls ldp bin 10.206.1.119 32
lib entry: 10.206.1.119/32, rev 1289
no local binding
remote binding: lsr: 10.59.243.132:0, label: 8615
TFE-D-L2L4724#
1 REPLY 1
Rising star
Re: ISR 4321-MPLS is not setting labels
Please provide
Sh run
Sh ip route
Sh mpls int
Sh mpls forwarding-table
Content for Community-Ad
FusionCharts will render here
