Showing results forĀ
Search instead forĀ
Did you mean:Ā
juniper configuration using NSO Juniper-junos NED issue
Ahmed Elsamahy
i am working on  a POC with Juniper routers and i am using NSO to configure l2vpn between juniper router and cisco one . i made a netsim network to test service package before adding it to customer NSO server . i am trying to put configuration  like below :-
set interfaces ge-0/3 unit 400 description "test"
set interfaces ge-0/3 unit 400encapsulation vlan-ccc
set interfaces ge-0/3 unit 400 vlan-id 403
set protocols l2circuit neighbor 10.0.0.50 interface ge-/3.403 virtual-circuit-id 32000
i found that i cannot type set and cannot type interfaces (interface name )  i must use interfaces interface (interface name) and this is not the right way when configuring juniper router
0 Replies 0
