l2 mpls loop prevention
eicc30000
how dos l2 mpls prevent loops? l2transport/ vpls. documents are also appreciated
thank you
Glen.
Peter Paluch
Hi Glen,
The loop-free connectivity between PEs is given by the IP/MPLS routing in the core of the provider and it is usually provided by a properly configured and correctly running routing protocol.
The basic pseudowire L2VPN as provided by MPLS does not provide any special prevention against loops. Pseudowires in MPLS L2VPN are point-to-point so a single pseudowire cannot create a loop. If the customer is using several pseudowires that could eventually be chained together to create a loop then it is the responsibility of the customer to avoid such scenarios.
With VPLS, I suggest consulting some of the following documents (also, searching the Google on the "VPLS loop prevention" provides lots of links):
http://fengnet.com/book/layer%202%20vpn%20architectures/ch15lev1sec1.html
http://www.google.sk/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.cisco.com%2Fapplication%2Fpdf%2Fen%2Fus%2Fguest%2Ftech%2Ftk891%2Fc1482%2Fccmigration_09186a00801ed3ea.pdf&rct=j&q=vpls%20loop%20prevention&ei=_csgTeK7N8y38gPuz4XcBQ&usg=...
Best regards,
Peter
Peter Paluch
Hi Glen,
Best regards,
Peter
As mentioned above VPLS uses split horizon loop protection, where traffic received from the network will not be forwarded back to the network.
