L2VPN Interworking Problem
apisak_num
There is a scenario:
(CE1)7600-----FE VLAN(dot1q)-----(PE1)7200VXR(NPE300)----FE----(PE2)7200VXR(NPE400)----atm----(ATM cloud)------frame relay------(CE2)2811
I want to bridge traffic between Ethernet interface to ATM interface on PE Router Cisco7200 with L2VPN Interworking.I used the IP mode interworking, VC is UP, I'm trying to ping from 7600 to 2811,it can't work.I want to know why? if you have any other suggestion to make the L2VPN Interworking configuration on 7600 to 2811 , please advise.
Thanks in advance
ritesh_mehta
Hi mate,
I think you need to configure Frame-Relay to ATM service interworking between PE2 & CE2.
Kindly refer below given link:
http://www.cisco.com/en/US/products/hw/switches/ps1893/products_configuration_guide_chapter09186a00800f375b.html#1010548
Ritesh
