08-24-2011 01:06 AM
Log from Cisco:
cisco1841Surgut(config)#crypto pki authenticate subca01
000129: Aug 19 17:57:13.056 GMT: CRYPTO_PKI: pki request queued properly
000130: Aug 19 17:57:13.056 GMT: CRYPTO_PKI: Sending CA Certificate Request:
GET /certsrv/mscep/mscep.dll/pkiclient.exe?operation=GetCACert&message=subca01 HTTP/1.0
User-Agent: Mozilla/4.0 (compatible; MSIE 5.0; Cisco PKI)
Host: sngst-ca
000131: Aug 19 17:57:13.056 GMT: CRYPTO_PKI: locked trustpoint subca01, refcount is 1
000132: Aug 19 17:57:13.060 GMT: CRYPTO_PKI: http connection opened
000133: Aug 19 17:57:13.060 GMT: CRYPTO_PKI: Sending HTTP message
% Error in receiving Certificate Authority certificate: status = FAIL, cert length = 0
000134: Aug 19 17:57:13.060 GMT: CRYPTO_PKI: Reply HTTP header:
HTTP/1.0
Host: sngst-ca
000135: Aug 19 17:57:13.064 GMT: CRYPTO_PKI: unlocked trustpoint subca01, refcount is 0
000136: Aug 19 17:57:13.064 GMT: CRYPTO_PKI: locked trustpoint subca01, refcount is 1
000137: Aug 19 17:57:13.808 GMT: CRYPTO_PKI: unlocked trustpoint subca01, refcount is 0
000138: Aug 19 17:57:13.808 GMT: CRYPTO_PKI: Reply HTTP header:
HTTP/1.1 200 OK
Content-Length: 4289
Content-Type: application/x-x509-ca-ra-cert
Server: Microsoft-IIS/7.5
Date: Fri, 19 Aug 2011 11:57:13 GMT
Connection: close
Content-Type indicates we have received CA and RA certificates.
000139: Aug 19 17:57:13.808 GMT: CRYPTO_PKI:crypto_process_ca_ra_cert(trustpoint=subca01)
000140: Aug 19 17:57:13.812 GMT: CRYPTO_PKI: status = 0x722(E_SIGNATURE_ALG_NOT_SUPPORTED : signature algorithm not supported): crypto_certc_pkcs7_extract_certs_and_crls failed
000141: Aug 19 17:57:13.812 GMT: CRYPTO_PKI: status = 0x722(E_SIGNATURE_ALG_NOT_SUPPORTED : signature algorithm not supported): crypto_pkcs7_extract_ca_cert returned
000142: Aug 19 17:57:13.812 GMT: CRYPTO_PKI: Unable to read CA/RA certificates.
000143: Aug 19 17:57:13.812 GMT: %PKI-3-GETCARACERT: Failed to receive RA/CA certificates.
000144: Aug 19 17:57:13.812 GMT: CRYPTO_PKI: transaction GetCACert completed
This is part of the config with regards to the certificates:
Building configuration...
Current configuration : 22062 bytes
! Last configuration change at 14:42:48 GMT Mon Aug 22 2011 by admin
version 15.1
no service pad
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki trustpoint TP-self-signed-3129615703
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3129615703
revocation-check none
rsakeypair TP-self-signed-3129615703
crypto pki trustpoint S1
enrollment terminal
serial-number none
fqdn cisco1841Surgut.xxx.local
ip-address none
password
rsakeypair cisco1841Surgut.xxx.local
crypto pki trustpoint subca01
enrollment mode ra
enrollment url http://xxx/certsrv/mscep/mscep.dll
ip-address none
password 7 08036D685F4D203636535B210E797C0D6666003224335358720F00070C2C5B394F
rsakeypair CP-RSAKey-1313751490188 2048 2048
crypto pki certificate chain test_trustpoint_config_created_for_sdm
crypto pki certificate chain TP-self-signed-3129615703
certificate self-signed 01
xxx
quit
crypto pki certificate chain S1
crypto pki certificate chain subca01
crypto key pubkey-chain rsa
addressed-key xxx
address xxx
key-string
xxx
quit
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 20
authentication rsa-encr
crypto isakmp key xxx address xxx
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA5
set isakmp-profile sdm-ike-profile-1
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA3
reverse-route
crypto dynamic-map VPN-USER-MAP 50
set transform-set VPN-TRANSFORM
match address 115
end
cisco1841Surgut#
10-11-2011 02:07 AM
Can you please close this thread and open a new thread in Security, as currently you have posted this under MPLS discussion.
Smitesh
10-11-2011 06:03 AM
I agree with Smitesh,
you can come this to Security -> VPN.
That being said "signature algorithm not supported: crypto_certc_pkcs7_extract_certs_and_crls failed "
What signature algo are you using? SHA2 is not yet supported.
M.
