05-04-2006 11:54 PM
Hello All,
We have deployed VPN's via ethernet and we integrate that via dot1q VLAN's on a subinterface on a GigEthernet. We then make those a member of a specific vrf forwarding VPN for example.
interface GigabitEthernet0/1.101
description VPN-CUST1
encapsulation dot1Q 101
ip vrf forwarding VPN-CUST1
ip address 192.168.125.1 255.255.255.252
ip address 192.168.126.1 255.255.255.252 secondary
no cdp enable
end
The client only wants the Head Office to see the branches, but not branch to branch for commercial and technical reasons eg. viruses/snooping etc. In our ATM subinterfaces, each branch has one subif so each has a different VRF and RD, we then just import the RD to the head office. But with VLAN based branches, we can't do it like this. I hope I had made it clear somehow. The question is, is there any other option to achieve this on a VLAN based subif VPN's? We are thinking of creating a subif VLAN for each branch but what if there are thousand branches, our VLANs will be exhausted easily. Hoping for your insights regarding this.
Thanks!
05-06-2006 03:16 AM
a Central Service VPN seems to be, what you need, as far as I understand.
The config could look like this:
ip vrf HQ
rd 65000:1
route-target import 65000:101
route-target export 65000:102
description HQ link
ip vrf forwarding HQ
no cdp enable
and on the PE, where the remote office is connected:
ip vrf RO1
rd 65000:1001
route-target export 65000:101
route-target import 65000:102
ip vrf RO2
rd 65000:1002
interface ATM0/0.1001
description remote office 1
ip vrf forwarding RO1
ip address 10.1.1.1 255.255.255.252
pvc 10/1001
encapsulation aal5snap
interface ATM0/0.1002
description remote office 2
ip vrf forwarding RO2
ip address 10.1.2.1 255.255.255.252
pvc 10/1002
Thus all the remote offices will only get the HQ routes and cannot connect to each other. The HQ will get all RO routes and only one link is needed to connect the HQ, not one link per RO.
Hope this helps! Please rate all posts.
Regards, Martin
05-06-2006 02:16 PM
can you clarify/detail this point "But with VLAN based branches, we can't do it like this." ?
regards,
cisand
05-07-2006 09:25 PM
Thanks Martin for the reply. Actually that's how we are doing it right now for ATM based branches. The problem arises when the remote branches are terminated virtually on a VLAN subinterface. Since they're a part of the same VLAN interface, they still could see each other regardless of the RD's since they're part of the same VRF.
For example:
interface FastEthernet0/1.723
description -CUST-A Braches-
encapsulation dot1Q 723
ip vrf forwarding VPN-CUSTOMERBRANCH
ip address 20.10.0.65 255.255.255.248 secondary
ip address 20.10.0.73 255.255.255.248 secondary
ip address 20.10.0.81 255.255.255.248 secondary
ip address 20.10.0.89 255.255.255.248 secondary
ip address 20.10.0.113 255.255.255.248 secondary
ip address 20.10.0.57 255.255.255.248
no cdp enable
end
With ATM there's no problem since we can create separate VRF's for each like what Martin has showed us. With Ethernet VLAN implementations on circuits terminated via MetroEthernet they will see each other.
I hope that somewhat clarified and thanks again for answering, I hope you can recommend a solution.
05-08-2006 07:03 AM
So you place all branches in a LAN. Per definition they should see each other!
MPLS VRFs are somewhat like virtual routers operating at network layer. Once you have given connectivity on OSI layer 2 there is little chance to avoid this.
So the best thing would be to have each branch in it´s own VLAN and place the VLAN interfaces in a separate VRF. If this is not supported by the MetroEthernet provider then there might be no chance at all to break connectivity other than installing firewalls at the branch offices.
In brief: in case you have several clients connected to a VLAN in a switch and connect them to one interface on a PE, this PE can not prevent their connectivity.
So: does the MetroEthernet provider offer you branch separation or not?
Regards, Martin
