MPLS @ Dynamips
aneesh.ts
I would like to learn MPLS using my lab setup with dynamips. If someone could provide me with some case study/configuration/topology to simulate the same, that would be very helpful..
Thanks in advance
AneesH
6 Replies 6
ozzyosbu1
Hello Aneesh
if u are looking for topology files for dynamips/dynagen , you can visit Hacki's forum.
http://7200emu.hacki.at/
Attached a simple MPLS topology i had created when i started studying MPLS
The forum mentioned above is a very good source though.
Narayan
Jayaprakash and Narayan,
Thank you very much for your comments.....
Hi Aneesh,
See if this helps too
http://ccieeverest.blogspot.com/2008/11/mpls-vpn.html
Although it goes one step more, configuring MPLS VPNs, it does involve configuring MPLS.
Lejoe
tarjbains
u can create ur own topoly in dyanagan note pad file as any normal routing topolgy just have to enable MPLS IP command. use 3660 router best router to use MPLS on daynagen cus it doesnt take much memory n supprot all command MPLS VPN n TE
Thanks bains for your update on 3660.
Will surely try that out and let you know.
AneesH
