MPLS hub and spoke
Ratheesh mv
HI all ,
I read that to achieve MPLS hub and spoke VPN the following things are needed .
1)Two different RT's - > I understood this point .
2)Different RDs -> I could not understand this point.
Could anyone  technically justify  the point number 2 (Different RDs)? I could not spot any challenge even if I use the same RD on hub and spokes.
Thanks in advance.
Harold Ritter
Hi @Ratheesh mv ,
MPLS VPN hub and spoke could work with the same RD in all sites, but it is normally recommended to use a different RD for each site.
Harold Ritter
Hi @Ratheesh mv ,
Hi  Harold Ritter,
Thanks for reply .
Is there any genuine reason behind recommending to use a different RD for each site?
Thanks in advance.
I write comment before but I think you don't get idea so I share this slide from ciscolive explain why we need unique RD.
