MPLS inside GRE
ubsaccount
This is my lab.  I configured OSPF for ISP and ran static route from Customer to ISP.  I built a GRE tunnel from Customer 1 to Customer 2. After building the tunnel I am trying to run site to site MPLS.  The LDP neighbors never come up.  I am not running MPLS through the ISP.
Can anyone tell me what I'm doing wrong?
R1
Customer 1
mpls label range 100 199
mpls label protocol ldp
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface Tunnel0
mpls ip
tunnel source Ethernet1/0
tunnel destination 4.4.4.2
interface Ethernet1/0
ip address 1.1.1.1 255.255.255.252
duplex full
ip route 0.0.0.0 0.0.0.0 1.1.1.2
mpls ldp router-id Loopback0
R2
ip address 1.1.1.2 255.255.255.252
ip ospf 1 area 0
duplex full
interface Ethernet1/1
ip address 2.2.2.1 255.255.255.252
ip ospf 1 area 0
duplex full
router ospf 1
redistribute static subnets
ip route 1.1.1.0 255.255.255.252 1.1.1.1
R4
ip address 4.4.4.1 255.255.255.252
ip ospf 1 area 0
duplex full
interface Ethernet1/2
ip address 3.3.3.2 255.255.255.252
ip ospf 1 area 0
duplex full
router ospf 1
redistribute static
ip route 4.4.4.0 255.255.255.252 4.4.4.2
R5
Customer 2
mpls label range 500 599
interface Loopback0
ip address 50.50.50.50 255.255.255.255
interface Tunnel1
ip address 192.168.1.2 255.255.255.0
mpls ip
tunnel destination 1.1.1.1
ip address 4.4.4.2 255.255.255.252
duplex full
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 4.4.4.1
willwetherman
By default LDP will try and establish a TCP adjacency with the discovered neighbors highest loopback IP address. If the loopback IP address is unreachable then the adjacency will fail.
Can you reach 50.50.50.50 from 10.10.10.10 over the GRE tunnel? If not you will need to add static routes to R1 and R5 to reach the loopback interfaces over Tunnel1.
willwetherman
BAM! THANK YOU!!!
I configured EIGRP on both customer site and put the loop0 into the network statements and it all works now!
Thats not a problem.
Please mark the answer as correct and rate if it has helped you. This will allow others to find this solution if they have a similar issue.
