MPLS ldp flapping
We have faced mpls ldp flapping issue. For example in random time during day log appears that  mpls ldp session gone down and up..
MPLS runs over OSFP as underlay network. I have not observed ospf flapping. All router are same ASR901 seriees
I have checked timers,physical connection  and it seems that everthing is OK.
6 Replies 6
show tcp brief
show mpls ldp neighbor
show mpls ldp discovery detail
do this in routers check holdtime config
Holdtime configuration in all routers is default configuration
LEN_MEATS-5_10G#sh mpls ldp discovery detail
Local LDP Identifier:
10.46.32.150:0
Discovery Sources:
Interfaces:
Vlan4066 (ldp): xmit/recv
Enabled: Interface config
Hello interval: 5000 ms; Transport IP addr: 10.46.32.150
LDP Id: 10.46.32.25:0
Src IP addr: 10.46.31.150; Transport IP addr: 10.46.32.25
Hold time: 15 sec; Proposed local/peer: 15/15 sec
Reachable via 10.46.32.25/32
Password: not required, none, in use
Clients: IPv4
Vlan4070 (ldp): xmit/recv
LDP Id: 10.46.32.6:0
Src IP addr: 10.46.31.106; Transport IP addr: 10.46.32.6
Reachable via 10.46.32.6/32
Clients: IPv4
Vlan4080 (ldp): xmit/recv
LDP Id: 10.46.32.60:0
Src IP addr: 10.46.31.66; Transport IP addr: 10.46.32.60
Reachable via 10.46.32.60/32
Clients: IPv4
Vlan4082 (ldp): xmit
Clients: IPv4
Vlan4084 (ldp): xmit/recv
LDP Id: 10.46.32.1:0
Src IP addr: 10.46.0.90; Transport IP addr: 10.46.32.1
Reachable via 10.46.32.1/32
Clients: IPv4
Vlan4088 (ldp): xmit/recv
LDP Id: 10.46.32.5:0
Src IP addr: 10.46.31.161; Transport IP addr: 10.46.32.5
Reachable via 10.46.32.5/32
Clients: IPv4
Vlan4090 (ldp): xmit/recv
LDP Id: 172.20.19.42:0
Src IP addr: 10.46.0.254; Transport IP addr: 172.20.19.42
Reachable via 172.20.19.42/32
Password: not required, neighbor, in use
Clients: IPv4
Vlan4061 (ldp): xmit/recv
LDP Id: 10.46.32.27:0
Src IP addr: 10.46.0.138; Transport IP addr: 10.46.32.27
Reachable via 10.46.32.27/32
Clients: IPv4
Targeted Hellos:
10.46.32.150 -> 192.168.254.4 (ldp): active, xmit
Enabled by: LDP Config,
Hello interval: 5000 ms; Transport IP addr: 0.0.0.0
10.46.32.150 -> 10.46.32.2 (ldp): active/passive, xmit/recv
Enabled by: MPLS AToM Circuit,
Hello interval: 10000 ms; Transport IP addr: 10.46.32.150
LDP Id: 10.46.32.2:0
Src IP addr: 10.46.32.2; Transport IP addr: 10.46.32.2
Hold time: 90 sec; Proposed local/peer: 90/90 sec
Reachable via 10.46.32.2/32
LEN_MEATS-5_10G#
The neighbor smallest  up time is 12 hrs
And ldp send/receive not 100% equal but near value.
and I see BGP and LDP reset?
can you check MTU size and drop in CPU queue.
Hello @MHM Cisco World
I have chechked mtu size. Mtu size is same under interface. But I see "output drops" when show interfase. Maybe it is related output queue. Because uplink interface is 10G and downlinks are 1G. It is expected situation.
