10-09-2012 06:34 AM
Im trying to expand my knowledge about MPLS but have a bunch of questions. Here is one. In a MPLS network, should the CEA1 from one side ping the the other CEB1 and viceversa? I can see the route in the routing table from both side, however ping doesnt past thru. Explain?
10-09-2012 08:03 AM
Hi Pedro,
Yuu should be able to ping, if you have setup MPLS L3 VPN correctly and if you don't have any configs to drop the ping
First you need to chec kif your LSP is fine.
1. Check if you have MPLS IP configured on the core devices and Core facing interfaces of PE. make sure you have cef enabled on the routers
To check if the LSP is fine, try a ping between PEs using source and destination as VRF IPs
Share your topoplogy. That will hep
10-15-2012 07:55 AM
rajs2;
Thanks for answering. Its ping from side to side now.
