MPLS Path switch
Wippe
R1 can reach R4 through R2 and R3,R2 is the main path
When I turn off the direct interface between R2 and R1,always lose at least 8 packets。
I was used ISIS-BFD between R1 and R2,R1 and R3
LDP-IGP SYN is also used in R1 , R2 and R3
But nothing changed,what should i do to to reduce packet loss?
7 Replies 7
M02@rt37
Hello @Wippe
Do you check BFD timers and verify that BFD sessions are up ?
LDP sessions are established ?
on ISIS process do you configure ?
mpls ldp sync
Best regards
Sure, use "bfd interval 999 min_rx 999 multiplier 5" and LDP sessions are established
yeah,you are right
However, in the mpls area, as they are all IBGP, IGP is needed to control routing
Wippe
When I change the metrics of ISIS, there will be no packet loss
But when i shutdown the interface , there will be loss
Whats the problem?
@Wippe
When you change the ISIS metrics, it triggers a topology change, and the routers recalculate the routing table. This might be happening faster than when you manually shut down the interface. Check the convergence time after shutting down the interface.
Best regards
Best regards
LDP-IGP SYN <<- this trick point can I see config of mpls igp syn
