04-04-2022 11:04 PM
Hello All,
I have the following set up and I am trying to understand 'set mpls experimental topmost' command. I have applied the following policy on PE1's ingress interface.
CE1---(vrf1)PE1(gi2)----P---P---PE2(vrf1)---CE2
policy-map policy1
class clas-default
set mpls experimental topmost 6
exit
g1 is pointing towards the CE1.
int gi1
service-policy input policy1
If I capture packets on gi2 of PE1, I do not see exp bits =6 in MPLS labels.
Is it the right behavior?
Sachin
Solved! Go to Solution.
04-05-2022 12:04 AM
is this configured other side
check example :
04-05-2022 12:04 AM
check example :
