MPLS-TE without Link state IGP
g.rodegari
Beginner
Beginner
Hi guys,
I'd like to understand if there are some ways to configure RSVP LSPs without using IGP like ISIS or OSPF, but just with static routing.
I've not found a way.
Anyone have some ideas?
Thank you!
and Best Regards,
G.
A colleague has founded an interesting link:
http://cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a0080699540.html
So the answer to your question isn't so obvious as used to think.
Kypamop
Beginner
Beginner
Hi!
Don't think you can. As you cannot do TE with EIGRP & RIP. The comprehensive knowledge of underlying topology is essential for Traffic Engineering.
Regards, Alex.
thank you for your answer.
The Point is that I'd like to use sctric configured ERO for RSVP and not rely to the Link state DB.
Thank you anyway,
G.
I think that is what actually I'm looking for!
I'll try soon as possible and I'll let you know
Many thanks and Best Regards (Also to your collegue ;-))
G.
Recognize Your Peers
