05-03-2021 02:29 AM
Hello everybody
I have a problem implementing Multicast in a small provider with some VRFs.
Attached is a diagram that can be used to better understand the typology.
As you can see we have two types of routers R1 is an XR and R2 is an xe, in both routers we have the vrf XXX.
The two routers are connected in MPLS through a cisco dwdm.
The client of vrf XXX needs to install a device that needs multicast traffic.
I configured the two nodes as per the extract, but something is missing in my opinion.
R1
multicast-routing
address-family ipv4
interface Loopback86
enable
interface TenGigE0/1/1/4
enable
vrf XXX
address-family ipv4
interface Loopback20
enable
interface TenGigE0/1/1/1
enable
router igmp
version 2
version 2
vrf XXX
join-group 239.0.0.1
version 2
version 2
R2
ip multicast-routing distributed
ip multicast-routing vrf XXX distributed
description Loopback vrf XXX
ip vrf forwarding XXX
ip address aaa.aaa.aaa.aaa 255.255.255.255
ip pim sparse-dense-mode
description Loopback global
ip address bbb.bbb.bbb.bbb 255.255.255.255
interface TenGigabitEthernet0/1/1
mtu 9148
ip address ccc.ccc.ccc.ccc 255.255.255.252
ip ospf network point-to-point
mpls ip
cdp enable
ip pim vrf XXX rp-address <Loopback 20 R1 >In R2 I can't see the route for group 239.0.0.1 Do you think I am missing something?
sh ip mroute vrf XXX
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector, p - PIM Joins on route,
x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 00:55:59/00:02:30, RP 10.86.20.1, flags: SJCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Loopback20, Forward/Sparse-Dense, 00:55:59/00:02:30
Thank you
05-04-2021 05:30 AM
Hello
can someone help me ?
05-04-2021 06:17 AM - edited 05-04-2021 06:18 AM
"Do you think I am missing something?"
Yes! I think quite a few things. I would start by saying that you have to clarify what profile you are using or intending to use? To have a better idea you should start by looking at the IOS XR documentation and IOS XE documentation. In general my feeling is that there's a little bit of confusion here (IGMP join commands on PEs as well as terminology is not super clear).
The following examples are based on the assumption that we are working in a MPLS L3VPN environment where things work and LDP is the protocol used to assign/distribute labels in the core. If that's not the case then we should probably start from building the backbone for L3VPN.
When it comes to Multicast VPNs (that's what you want yeah?) let's assume you want PIM in the core, here's the config of one PE (the other will be practically the same thing):
router bgp 123 address-family ipv4 mdt ! neighbor 2.2.2.2 <-- other PE or RR for the IPv4 mdt AF address-family ipv4 mdt ! multicast-routing address-family ipv4 mdt source Loopback0 <-- loopback 0 is used for MPLS reachability and needs to be enabled interface all enable ! vrf XXX address-family ipv4 mdt data 232.0.1.0/24 mdt default ipv4 232.0.0.1 interface all enable <-- enable all the interfaces in the vrf XXX ! end
Now just to make another example let's assume you do not want PIM in the core, but rather implement MLDP here's the config of one PE (the other will be practically the same thing:
vrf XXX
vpn id 1:1
mpls ldp
mldp
logging notifications
address-family ipv4
multicast-routing
address-family ipv4
interface lo0 enable
vrf XXX
address-family ipv4
mdt source lo0
mdt default mldp ipv4 2.2.2.2
router pim
vrf cust_2
address-family ipv4
rpf topology route-policy rpf-for-XXX
set core-tree mldp-default
end-policy
endI would rather skip the rest of profile configuration examples as each might slightly differ from the rest based on specific requirements and different scenarios.
PS.
IGMP join should not be on PEs but rather on the client itself, not sure why you would have it on the PE to be honest.
Thanks, L.
05-05-2021 06:20 AM
Hi Loris
Thanks for your help.
I confirm that we are working in a fully functional MPLS L3VPN network and LDP is the protocol we are using for the distribution of the labels in the core.
This scenario is a lab created in EVE-NG to test multicast, for this reason I perform the join from the PE but in reality it will be in the CE (C9400).
The network in production is made up of 20 routers which have a relationship in BGP with the RR.
The purpose of my LAB is to carry the multicast through MLDP, I believe the profile is 6.
I try to configure and update you, thanks again
