MVPN Extranet difference between IOS 12.2SX and 15.1SY
Hello community!
I'm preparing to migrate on our Cat6500 from IOS 12.2SXI13 to the latest 15.1SY and i find a problem with MVPN Extranet Support.
With the totally the same configuration under 12.2 MVPN Extranet works fine, but under 15.1 it doesn't withour some additional config (see below). We using the source MVRF on the receiver PE (Option 2).
Multicast source PE:
interface Loopback1
 description Loopback for VRF iTV PIM RP
 ip vrf forwarding iTV
 ip address 212.49.127.127 255.255.255.255
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip pim sparse-mode
ip vrf iTV
 rd 12668:20
 route-target export 12668:20
 route-target import 12668:20
 mdt default 232.255.255.20
 mdt data 232.255.20.0 0.0.0.255
router bgp 12668
address-family ipv4 vrf iTV
  redistribute connected metric 0
  redistribute static metric 0
  no synchronization
  network 212.49.127.0
 exit-address-family
ip route vrf iTV 212.49.127.0 255.255.255.0 Null0
ip multicast-routing
ip pim ssm default
ip multicast-routing vrf iTV
ip pim vrf iTV rp-address 212.49.127.127
end
Receiver PE:
ip vrf iTV
 rd 12668:20
router bgp 12668
  no synchronization
 exit-address-family
ip pim ssm default
vrf definition Inet
 rd 12668:10
 route-target export 12668:10
 route-target import 12668:10
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
router bgp 12668
address-family ipv4 vrf Inet
  no synchronization
 exit-address-family
ip multicast-routing vrf Inet
ip pim vrf Inet rp-address 212.49.127.127
end
I have receiver in vrf Inet for group 239.255.2.122:
sh ip igmp vrf Inet groups 239.255.2.122
IGMP Connected Group Membership
Group Address    Interface                Uptime    Expires   Last Reporter   Group Accounted
239.255.2.122    Vlan3303                 01:10:08  00:02:31  169.254.106.34
But i don't see (S,G) entry for this group:
sh ip mroute vrf Inet 239.255.2.122
Load for five secs: 12%/3%; one minute: 7%; five minutes: 6%
Time source is NTP, 17:44:32.284 Ural Thu Aug 20 2015
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.2.122), 00:00:32/00:02:27, RP 212.49.127.127, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Vlan3303, Forward/Sparse, 00:00:32/00:02:27
sh ip mroute vrf iTV 239.255.2.122
Group 239.255.2.122 not found
Multicast senders in vrf iTV and using 212.49.127.0/24 subnet. Something wrong with RPF here:
sh ip rpf vrf Inet 212.49.127.0
 failed, no route exists
But in unicast routing table all necessary routes is present:
sh ip route vrf Inet 212.49.127.0
Routing Table: Inet
Routing entry for 212.49.127.0/24, 49 known subnets
  Variably subnetted with 3 masks
B        212.49.127.0/24 [200/1500] via 212.49.96.12, 00:00:12
B        212.49.127.12/30 [200/1500] via 212.49.96.12, 00:00:12
B        212.49.127.16/30 [200/1500] via 212.49.96.12, 00:00:12
B        212.49.127.24/30 [200/1500] via 212.49.96.12, 00:00:12
B        212.49.127.28/30 [200/1500] via 212.49.96.12, 00:00:12
If i use RPF for MVPN Extranet Support Using Static Mroutes (ip mroute vrf Inet 212.49.127.0 255.255.255.0 fallback-lookup vrf iTV) or Multicast VPN Extranet VRF Select (ip multicast vrf Inet rpf select vrf iTV group-list XXX) all works fine.
But if i use the source MVRF on the receiver PE router (Option 2) for extranet links no additional configuration is required for RPF resolution...
Also i found one more workaround - just put MDT default config under receiver VRF. But why i need to do this? All my senders in VRF iTV, VRF Inet just for delivering multicast traffic to the end instance. So i don't need additional unnecessary MDT default traffic in VRF Inet.
If i reload Cat6500 to 12.2SXI13 all works good without any MDT defaults in a receiver VRF (Inet), static mroutes and Extranet VRF Selection:
(*, 239.255.2.122), 1w4d/stopped, RP 212.49.127.127, flags: SJC
  Incoming interface: Tunnel0, RPF nbr 212.49.96.12, using vrf iTV, RPF-MFD
    Vlan3372, Forward/Sparse, 00:01:16/00:02:45, H
    Vlan3373, Forward/Sparse, 00:03:10/00:02:42, H
    Vlan3375, Forward/Sparse, 00:05:01/00:02:39, H
    Vlan3327, Forward/Sparse, 00:17:12/00:02:43, H
    Vlan3331, Forward/Sparse, 00:28:04/00:02:44, H
    Vlan3380, Forward/Sparse, 00:53:41/00:02:39, H
    Vlan3357, Forward/Sparse, 00:57:41/00:02:57, H
    Vlan3390, Forward/Sparse, 01:04:13/00:02:58, H
    Vlan3365, Forward/Sparse, 09:41:17/00:02:46, H
    Vlan3304, Forward/Sparse, 11:01:51/00:02:59, H
    Vlan3358, Forward/Sparse, 3d10h/00:02:44, H
(212.49.127.18, 239.255.2.122), 1w4d/stopped, flags:
(*, 239.255.2.122), 7w0d/stopped, RP 212.49.127.127, flags: SJCE
  Incoming interface: Tunnel0, RPF nbr 212.49.96.12, Partial-SC
  Outgoing interface list: Null
  Extranet receivers in vrf Inet:
(*, 239.255.2.122), 1w4d/stopped, RP 212.49.127.127, OIF count: 11, flags: SJC
(212.49.127.18, 239.255.2.122), 7w0d/00:02:59, flags: TYE
  Incoming interface: Tunnel0, RPF nbr 212.49.96.12, RPF-MFD, MDT:[212.49.96.12,232.255.20.185]/00:02:03
  (212.49.127.18, 239.255.2.122), 1w4d/00:02:50, OIF count: 11, flags:
RPF information for ? (212.49.127.0)
  RPF interface: Tunnel0
  RPF neighbor: ? (212.49.96.12)
  RPF route/mask: 212.49.127.0/24
  RPF type: unicast (bgp 12668)
  RPF recursion count: 0
  Doing distance-preferred lookups across tables
  BGP originator: 212.49.96.12
I did't post all configuration like "address-family ipv4 mdt", interface config and etc because it is very big output...
Anyone have the same issue? Do you know about different RPF behaviour with MVPN Extranet between 12.2 and 15.1 (i tried 15.1(1)SY5/SY4/SY3 and 15.1(2)SY5/SY4)?
Thanks in advance!
0 Replies 0
