Ospf Scaling Issues
patcbr600
Hi All,
Does any one know the maximum number of ospf adjencies that cisco router support when accting as a PE device connected to a CE .
Many Thanks
Giuseppe Larosa
Hello Patricio,
heavier duties are for the DR / BDR on lan segment.
In normal routing it is not recommended to have more then 40-50 routers in the same lan segment.
Possible suggestions are to divide in multiple lan segments, to use two PE nodes and make them DR alternate on vlans/subnets
Hope to help
Giuseppe
