ā04-04-2011 08:54 AM
Can we have trunk between more than 2 CE over MPLS in short we are looking for the point to multipoint MPLS L2 VPN where more than 2 CE will share the common ethernet segment over MPLS to share the vlan database
Let me give more info @ solution which we are trying find out
CE1,CE2,CE3 & CE4 are the core switches at respective location, we are looking for the same vlan database between these core switches over the MPLS
CE1 will be connected to PE1
CE2 will be connected to PE2
CE3 will be connected to PE3
CE4 will be connected to PE4
so can we have the L2 vpn between CE1,CE2,CE3 & CE4 where the interface connected to respective PE's will be TRUNK ?
ā04-04-2011 08:56 AM
I think VPLS should help you. But I am not MPLS expert and I can't confirm. You can study this doc.
http://www.cisco.com/application/pdf/en/us/guest/tech/tk891/c1482/ccmigration_09186a00801ed3ea.pdf
Leon Lai
ā04-04-2011 12:26 PM
hi
thanks for the pdf, I had tried the VPLS earlier. the circuit are coming up but I am not able to ping between CE's Vlan ip address although VC are up
PE end config
interface GigabitEthernet1/35
description L2 Connectivity to KBL039SW1 (TEMP)
switchport
switchport access vlan 100
switchport mode dot1q-tunnel
l2protocol-tunnel cdp
CE-1 end config
interface FastEthernet1/0/48
switchport mode trunk
end
int vlan 100
ip address 10.10.10.1 255.255.255.0
other end vlan 100 ip address is 10.10.10.2 but not able to ping this ip address from CE-1
any guess what cpuld be the problem?
ā04-05-2011 05:50 AM
Can you share the topology diagram ? are you on the CE side or PE side ??
ā04-05-2011 05:55 AM
Did change System MTU > 1500? QinQ requires MTU > 1500. You must reboot switch after adjusted MTU size.
ā05-04-2011 01:04 PM
You could xconnect a specific vlan at each site and bring that xconnection back to your hub on seperate sub interfaces.
It would give you a hub and spoke design. Little cheaper if you do not have VPLS compatible hardware.
Would be similair to Frame Relay PVCs/DLCIs.
