Policy-based routing on vrf instance
iaglindro
Good Day!
this is my scenario: i have two links connecting to a customer one 512kbps and the othe 64kbps. This customer has a colocated email server and several other servers.
i'm on a dilemma right now of finding a way to have the traffic to and from the email server be ALWAYS on the 64kbps line, and the rest of the traffic on the 512kbps line but the catch is that all of my interfaces (512, 64, and the LAN) belong to the same vrf instance.
please help me find a solution and if none, any suggestions or workarounds?
help very much appreciated.
cheers,
-ian
gmarogi
Level 5
Level 5
I think you can still use policy based routing since the interfaces are part of the same VRF.
can youn tell me how? i did try it but no success, maybe you can suggest.
waris
I think you can try VRF selection or VRF lite.Probably they can handle this situation better than PBR.
PBR is not supported through a single vrf instance. FYI. i did another procedure to sove this until IOS technology can support PBR on a single vrf instance.
