PPPoE scenario for MPLS VPN
devang_etcom
Level 7
Level 7
I do have one scenario where CE1/CE2 is connected with SW1 port Fa0/1 and port 0/2.
CE1 is belong to VLAN100 and CE2 is belong to VLAN200. Now SW1 is connected with PE1. Link between PE1 and SW1 is trunklink with .100 and .200 subinterfaces. Now I want to have CE1 as a part of VRF CE1 and CE2 as a part of VRF CE2. I want to use PPPoE to achieve this. I tried to create multiple VPDN group with accept-dialin and protocol pppoe but router is allowing only one VPDN PPPoE group! and I can assign only one Virtual-template interface to that VPDN group so how can I achieve my requirement?
thanks
Devang Patel
7 Replies 7
devang_etcom
Level 7
Level 7
I found the way to achieve that is to use the bba-group! there I can crate the multiple PPPOE bba profile and can use different virtual template interface to achieve it!
Experts if you have any other ways then which will be more scalable then please let me know!
thanks
Devang Patel
Hello Devang,
bba profile was introduced to provide support for multiple PPPoX groups on the same node.
So this is the right way to perform this activity
Hope to help
Giuseppe
hi Giuseppe
If possible could you elaborate why PPPOE is required for VPDN. I donot have any understanding of the scenario may be we are not providing. If possible can you provide some links which can clear the doubts.
regards
shivlu jain
hi Giuseppe
thanks for giving the link. Will come back to you by tomorrow with lot of queries.
regards
shivlu jain
Shivlu,
PPPoE with VPDN was the old implementation method, It has a limitation of creating only one PPPoE profile and you can have one virtual-temp interface assigned to it! but if you have multiple client and all those client has different kind of requirement then you will need to have multiple PPPoE profile on your agg router, bba profile will allow you to create multiple PPPoE profile! I was trying to test MPLSVPN with PPPoE. For best reference you can refer to cisco 12.4T IOS documentation as well as few books like MPLS VPN arch vol2 chapter 2, as well as mpls base broadband access vpn book.
Let me know if you need any more information!
thanks,
Devang Patel
thanks devang
For start up these need are sufficient.
regards
shivlu jain
