Prime Fulfillment 6.2 - VPN Topology issues again
Vorvalyov1023
Hi guys!
I got a question about my topology again. My Topology Apples is now working (since
https://supportforums.cisco.com/message/3659140#3659140)
But  there are no links or VPNs in it, just P and PE devices (see attached  file, sorry, I have to delete some IP addresses octets from the  Picture,). Furthermore the VPN Topology hangs often. No visible Errors,  no Error messages. I have a log from Java and it sais that I got an  exception:
network: Cache entry not found [url: https://10.  .   .21:8443/isc/home/ext/../../etc/boot.properties, version: null]
network: Connecting https://10.  .   .21:8443/isc/home/ext/../../etc/boot.properties with proxy=DIRECT
network: Server https://10.  .   .21:8443/isc/home/ext/../../etc/boot.properties requesting to set-cookie with "JSESSIONID=345B5415A338AB1C6DF63A1C4271A577; Path=/isc; Secure"
java.io.FileNotFoundException: https://10.  .   .21:8443/isc/home/ext/../../etc/boot.properties
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
    at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
    at com.cisco.vpnsc.time.TimeDiff.setup(TimeDiff.java:110)
    at com.cisco.vpnsc.time.TimeDiff.<init>(TimeDiff.java:40)
    at com.cisco.vpnsc.time.TimeDiff.getInstance(TimeDiff.java:87)
    at com.cisco.vpnsc.repository.dbaccess.PersistentObject.setTimestamp(PersistentObject.java:1829)
    at com.cisco.vpnsc.repository.dbaccess.PersistentObject.insert(PersistentObject.java:2202)
    at com.cisco.vpnsc.repository.dbaccess.PersistentObject.apply(PersistentObject.java:224)
    at com.cisco.vpnsc.repository.ual.RepUALog.apply(RepUALog.java:97)
    at com.cisco.vpnsc.repository.ual.UALogManager.log(UALogManager.java:139)
    at com.cisco.vpnsc.repository.ual.UALogManager.log(UALogManager.java:76)
    at com.cisco.vpnsc.repository.rbac.RbacManager.login(RbacManager.java:196)
    at com.cisco.vpnsc.apps.csmconsole.comp.LoginComponent.login(LoginComponent.java:241)
    at com.cisco.vpnsc.apps.csmconsole.comp.LoginComponent.login(LoginComponent.java:125)
    at com.cisco.vpnsc.apps.csmconsole.ManagementConsole.login(ManagementConsole.java:795)
    at com.cisco.vpnsc.apps.csmconsole.Manageme    ntConsole.<init>(ManagementConsole.java:176)
    at com.cisco.vpnsc.apps.csmconsole.ManagementConsole.main(ManagementConsole.java:98)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at com.sun.javaws.Launcher.executeApplication(Unknown Source)
    at com.sun.javaws.Launcher.executeMainClass(Unknown Source)
    at com.sun.javaws.Launcher.doLaunchApp(Unknown Source)
    at com.sun.javaws.Launcher.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
At the same time TE Topology is working good. How can I resolve this trouble. Please help me, friends.
And  one more detail: I have this situation on my Windows 7 PC. At the same  time WinXP PC cant run this Applet. It gives me an error and the same  log.
0 Replies 0
