Problems with mpls ldp label command.
Daniel Maloney
Hi!
I'm having a strange issue with mpls ldp label command. Cisco's website says this command was introducedn in IOS version 12.2(33)SRC
But as you can see I can't type this command..  I'm using GNS3.
2 Accepted Solutions
Mark Malone
if its not there its not supported in that version its nothing to do with GNS3 as there full images not stripped down like the Linux IOUs , a lot of commands were removed between the progression of v12 to v15 it was huge change ]you can check and compare images with this tool and what commands they support and what they were changed too
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Only Cisco could tell you why they removed it , lot of things disappeared and were added going from 12 - 15 , best thing is just check the feature navigator that gets updated more frequently than the docs
Mark Malone
Hi Mark, I've tested with 15.2 and it worked.. Can't understand why it is not working with 15.1... Cisco doc says it came out with 12.2...
Thank you for helping me!
