pieterj
Beginner
QPPB in VRF on ASR9K
Hi everyone,
I was wondering if anyone has used QPPB on a interface that is in a VRF on the ASR9K
I have setup my BGP Policy and applied it to BGP under the vrf instance. I have confirmed in CEF that prefixes that match the community has the right classification.
0.0.0.0/0, version 9451648, proxy default, internal 0x4000021 (ptr 0xad3a0294) [1], 0x0 (0x0), 0x0 (0x0)
Updated Nov 25 22:38:10.135
Prefix Len 0, traffic index 0, precedence routine (0), priority 3
IP Precedence: 3
   via xxxxx, 3 dependencies, recursive [flags 0x0]
    path-idx 0 [0xad3c2884 0x0]
    next hop xxxxx
I am classifying traffic from the inside outbound as it enters the inside interface as follows
ipv4 bgp policy propagation input ip-precedence destination
I have applied an input shaping policy under the interface so that all traffic that matches Prec 3 is shaped down to 25M as it enters the interface but I’m not seeing any matches on the policy. If I apply the same policy as egress on the opposite side of the router as the traffic leaves I can see the matches.
This would indicate that my classification is working but the shaping is applied before qppb classifies the traffic instead of after it is classified.
Here is the config
route-policy BGP-QPPB-SET-QOS-PREC
  if community matches-any (100:103) then
    set ip-precedence 3
  else
    if community matches-any (100:102) then
      set ip-precedence 2
    else
      set ip-precedence 0
    endif
  endif
  end-policy
router bgp 100
  vrf Internet
  address-family ipv4 unicast
   table-policy BGP-QPPB-SET-QOS-PREC
interface GigabitEthernet0/3/0/2.2249
description Outside Interface
  vrf Internet
  ipv4 bgp policy propagation input ip-precedence source
interface TenGigE0/3/0/0.993
description Inside Interface
service-policy input CUST-25INTL-100NATL
  vrf Internet
  ipv4 mtu 1500
class-map match-any QOS-PREC3
match precedence 3
end-class-map
policy-map CUST-25INTL-100NATL
class QOS-PREC3
  shape average 25 mbps 125 ms
class class-default
shape average 100 mbps 125 ms
If I do the following I do see matches on the policy for Prec 3 traffic,  But I dont realy want to shape outbound as the external interface is a shared interface where many customers traffic will pass across.
  vrf Internet
  service-policy output CUST-25INTL-100NATL
  vrf Internet
0 REPLIES 0
