08-03-2017 01:35 AM
Hello All,
Refer: attached network architecture design
I have a network design as attached. Currently we are migrating from IPv4 to IPv6 in our organization & are stuck with one issue. Below is the config from Cisco 6509 catalyst switch for your reference.
CONFIGURATION of Cisco 6509 Catalyst Switch:
Interface Configs:
Interface Te3/2
vrf forwarding PUB
ip address 10.240.2.5 255.255.255.0
no ip redirects
no ip unreachables
ipv6 address 2403:BE80:1000::1/39
ipv6 enable
End
Vlan 25
interface Vlan25
vrf forwarding SHARED
ip address 10.190.4.254 255.255.255.128
no ip redirects
no ip unreachables
ipv6 address 2403:BE80:2000::1/39
ipv6 enable
End
Interface Fa4/32
Switchport
Switchport access vlan 25
Switchport mode access
VRF configs:
vrf definition PUB
rd 200:200
route-target export 200:200
route-target import 300:300
route-target import 200:200
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf definition SHARED
rd 300:300
route-target export 300:300
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
BGP Config:
router bgp 65535
address-family ipv4 vrf SHARED
redistribute connected
redistribute static
no synchronization
exit-address-family
address-family ipv6 vrf SHARED
redistribute static
no synchronization
exit-address-family
address-family ipv4 vrf PUB
redistribute static
default-information originate
no synchronization
exit-address-family
address-family ipv6 vrf PUB
redistribute static
no synchronization
exit-address-family
PROBLEM DESCRIPTION:
Both the Networks (1000 & 2000) are seen in the ipv6 routing table under their specific vrf's as ebgp learned routes, but not able to ping each other. Output is as under
Cisco6509#sh ipv6 route vrf SHARED
IPv6 Routing Table - SHARED - 16 entries
Codes: C - Connected, L - Local, S - Static, U - Per-user Static route
B - BGP, R - RIP, I1 - ISIS L1, I2 - ISIS L2
IA - ISIS interarea, IS - ISIS summary, D - EIGRP, EX - EIGRP external
O - OSPF Intra, OI - OSPF Inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
B 2403:BE80:800::/39 [20/0]
via Vlan20, directly connected
B 2403:BE80:1000::/39 [20/0]
via TenGigabitEthernet3/2, directly connected
C 2403:BE80:2000::/39 [0/0]
via Vlan25, directly connected
L 2403:BE80:2000::1/128 [0/0]
via Vlan25, receive
Cisco6509#sh ipv6 route vrf PUB
IPv6 Routing Table - PUB - 7 entries
S ::/0 [1/0]
via 2403:BE80:1000::2
C 2403:BE80:800::/39 [0/0]
L 2403:BE80:800::1/128 [0/0]
via Vlan20, receive
C 2403:BE80:1000::/39 [0/0]
L 2403:BE80:1000::1/128 [0/0]
via TenGigabitEthernet3/2, receive
B 2403:BE80:2000::/39 [20/0]
PING OUTPUT:
Cisco6509#ping vrf SHARED 2403:BE80:1000::1
Sending 5, 100-byte ICMP Echos to 2403:BE80:1000::1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Cisco6509#
Cisco6509#ping vrf PUB 2403:BE80:1000::1
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/0 ms
Cisco6509#
Can anybody put some light on this above issue? do let me know if anything else needs to be configured to achieve inter vrf routing under IPv6.
Please note that with IPv4 it is working perfectly fine with same config as above.
Awaiting for a solution.
With best Regards,
Sunny
