08-01-2012 03:58 AM
I'm a bit confused by this setup that i'm trying to achieve.
The setup is classic though, I have one VRF for education (EDU), one for administrators (ADM) and then a shared VRF (GEM) like this:
ip vrf ADM
description *** ADMIN NET ***
rd 2:2
export map ADM-to-EDU
route-target export 2:2
route-target import 1:1
route-target import 2:2
ip vrf EDU
description *** ELEV NET ***
rd 3:3
route-target export 3:3
route-target import 33:33
route-target import 3:3
ip vrf GEM
description *** GEMENSAM NET ***
rd 1:1
route-target export 1:1
As you can see, i have also configured an export map for vrf ADM, which i'm then importing routes from.
the Map looks as follows:
access-list 1 permit 172.18.254.37
route-map ADM-to-EDU permit 10
match ip address 1
set extcommunity rt 33:33 additive
A relevant part of the ip setup is as follows:
interface Loopback3
ip vrf forwarding EDU
ip address 3.3.3.3 255.255.255.255
interface Loopback37
ip vrf forwarding ADM
ip address 172.18.254.37 255.255.255.255
I'm running BGP:
router bgp 65235
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf GEM
redistribute connected
redistribute static
default-information originate
no synchronization
exit-address-family
address-family ipv4 vrf EDU
redistribute static
no synchronization
exit-address-family
address-family ipv4 vrf ADM
redistribute static
no synchronization
exit-address-family
Now, the thing is, the leaking is working, i can see the leaked route in the EDU routing table below,
Router#sh ip route vrf EDU
Routing Table: EDU
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 172.19.16.5 to network 0.0.0.0
1.0.0.0/32 is subnetted, 1 subnets
B 1.1.1.1 is directly connected, 04:53:31, Loopback1
3.0.0.0/32 is subnetted, 1 subnets
C 3.3.3.3 is directly connected, Loopback3
172.19.0.0/32 is subnetted, 1 subnets
B 172.19.16.5 is directly connected, 02:27:51, Loopback0
172.18.0.0/32 is subnetted, 1 subnets
B 172.18.254.37 is directly connected, 00:32:14, Loopback37
B* 0.0.0.0/0 [20/0] via 172.19.16.5 (GEM), 02:08:42
but i cannot reach it:
Router#ping vrf EDU 172.18.254.37
Sending 5, 100-byte ICMP Echos to 172.18.254.37, timeout is 2 seconds:
Success rate is 0 percent (0/5)
But if i run "debug ip packet" and the perform another ping, i get this result which i think is a bit weird? to me it seems as if it works.
*Mar 1 05:42:40.562: IP: tableid=2, s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:40.566: IP: s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), len 100, sending
*Mar 1 05:42:40.574: IP: tableid=2, s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:40.578: IP: s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), len 100, rcvd 3
*Mar 1 05:42:40.578: IP: tableid=2, s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:40.578: IP: s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), len 100, sending
*Mar 1 05:42:40.578: IP: tableid=2, s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:40.578: IP: s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), len 100, rcvd local pkt.
*Mar 1 05:42:42.562: IP: tableid=2, s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:42.566: IP: s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), len 100, sending
*Mar 1 05:42:42.574: IP: tableid=2, s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:42.578: IP: s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), len 100, rcvd 3
*Mar 1 05:42:42.582: IP: tableid=2, s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:42.586: IP: s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), len 100, sending
*Mar 1 05:42:42.590: IP: tableid=2, s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:42.590: IP: s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), len 100, rcvd local pkt.
*Mar 1 05:42:44.562: IP: tableid=2, s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:44.566: IP: s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), len 100, sending
*Mar 1 05:42:44.570: IP: tableid=2, s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:44.574: IP: s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), len 100, rcvd 3
*Mar 1 05:42:44.578: IP: tableid=2, s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:44.578: IP: s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), len 100, sending
*Mar 1 05:42:44.578: IP: tableid=2, s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:44.578: IP: s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), len 100, rcvd local pkt.
*Mar 1 05:42:46.566: IP: tableid=2, s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:46.570: IP: s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), len 100, sending
*Mar 1 05:42:46.570: IP: tableid=2, s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:46.570: IP: s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), len 100, rcvd 3
*Mar 1 05:42:46.570: IP: tableid=2, s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:46.570: IP: s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), len 100, sending
*Mar 1 05:42:46.570: IP: tableid=2, s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:46.574: IP: s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), len 100, rcvd local pkt.
*Mar 1 05:42:48.562: IP: tableid=2, s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:48.566: IP: s=3.3.3.3 (local), d=172.18.254.37 (Loopback37), len 100, sending
*Mar 1 05:42:48.566: IP: tableid=2, s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), routed via RIB
*Mar 1 05:42:48.570: IP: s=3.3.3.3 (Loopback37), d=172.18.254.37 (Loopback37), len 100, rcvd 3
*Mar 1 05:42:48.574: IP: tableid=2, s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:48.574: IP: s=172.18.254.37 (local), d=3.3.3.3 (Loopback0), len 100, sending
*Mar 1 05:42:48.582: IP: tableid=2, s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), routed via RIB
*Mar 1 05:42:48.582: IP: s=172.18.254.37 (Loopback0), d=3.3.3.3 (Loopback0), len 100, rcvd local pkt.
Router#
However, if i add leaking for 3.3.3.3 in ADM vrf like this:
access-list 2 permit 3.3.3.3
route-map EDU-to-ADM permit 10
match ip address 2
set extcommunity rt 22:22 additive
ip vrf ADM
rd 2:2
route-target import 22:22 < - added line
ip vrf EDU
rd 3:3
export map EDU-to-ADM < - added line
Then it will work:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/16 ms
So actually, my big question is, am i doing this the right or wrong way? i'm a bit confused.
Sorry about the rant, maybe it will clarify some things for others who are confused, or maybe just make it worse!
Some additional thoughts:
Why can't i perform this ping, shouldnt this work?
Router#ping vrf GEM 172.18.254.37
Router#
bgp info:
Router#sh ip bgp vpnv4 all
BGP table version is 79, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:1 (default for vrf GEM)
*> 0.0.0.0 172.19.16.5 0 32768 ?
*> 1.1.1.1/32 0.0.0.0 0 32768 ?
*> 2.2.2.2/32 0.0.0.0 0 32768 ?
*> 3.3.3.3/32 0.0.0.0 0 32768 ?
*> 172.18.254.37/32 0.0.0.0 0 32768 ?
*> 172.19.16.5/32 0.0.0.0 0 32768 ?
Route Distinguisher: 2:2 (default for vrf ADM)
Route Distinguisher: 3:3 (default for vrf EDU)
Router#
Solved! Go to Solution.
08-08-2012 05:07 AM
Hello Tommy,
your understanding is correct to build two way IP communication between two VRFs that are not importing each other route targets you need to use an export map that will add a modified RT in order to perform a so called partial extranet in both directions as you have seen in your tests.
You are close to the solution and you may have found it by yourself
ip prefix-list 2 seq 5 permit 172.19.0.0/16
You need to rewrite this in the following way:
ip prefix-list 2 seq 5 permit 172.19.0.0/16 le 32
Only in this way you can take full advantage of the capabilities of IP prefix-list to describe all the IP subnets in EDU VRF topology that are within the 172.19/16 block.
I would suggest to use alphanumeric names like PL-EDU-to-ADM for the names of the prefix lists, the use of numbers makes less clear the configuration (in my opinion and experience)
Hope to help
Giuseppe
08-01-2012 12:22 PM
Try to ping by sourcing the interface or the ip.
